Steering Head Bearing - Help - Road Glide Forums
post #1 of 9 (permalink) Old 10-06-2012, 05:31 PM Thread Starter
1st Sgt's Avatar
I've the front of the 2011 RGU broken down per the manual - and can see the adjuster nut - even have a tool to reach the nnut but not sure how to proceed. IS the adjuster nut fairly tight so need to tap the tool with a mallet? Should I be able to reach in there and turn it fairly easily? What has someone found to be the easiest way to reach the adjuster nut? Any video? (already looked on you tube but not finding anything other than where the nut is)
Thanks
1st Sgt is offline
post #2 of 9 (permalink) Old 10-06-2012, 06:15 PM
rageglide's Avatar
You first have to loosen the top clamp bolt, and also the lower pinch bolts for the legs.
Yes, you are going to need to tap on the tool with a small hammer.
It's not easy to get to, even if you buy/fabricate the special tool, you can also get to it with a long narrow drift. You need to crank bars all the way right and get very low to see the star nut... they probably couldn't have made it any more difficult to get to if they had tried... tap tap tap, test it... just go slow.
rageglide is offline
post #3 of 9 (permalink) Old 10-06-2012, 10:00 PM
laxinharley's Avatar
Perfect answer. I bent a long ass screwdriver. Take your time tap it a little and check the fall away. It's a major pain in the ass.
laxinharley is offline
post #4 of 9 (permalink) Old 10-07-2012, 01:45 AM
rageglide's Avatar
no doubt, pain in the ass, however, it's a bit easier than working on a batwing and a roadking.
post #5 of 9 (permalink) Old 10-07-2012, 08:00 AM
hotrodad's Avatar
try this link
you got it. easy.
here's a link for how too. hope it helps
click here for help
HRD
2005 FLTRi
Black Pearl
Live to Ride ~ Ride to Live
hotrodad is offline
post #6 of 9 (permalink) Old 10-07-2012, 09:29 AM Thread Starter
1st Sgt's Avatar
DONE! What a major PITA. Thanks for the help everyone. BTW - I greased teh bearing per the manual and like others - it took a whole lot of grease before it peeked out from the bearings.
1st Sgt is offline
post #7 of 9 (permalink) Old 10-07-2012, 10:56 AM
GRTSHRK's Avatar
Yesterday I decided to check the grease in my head bearing. Pumped half a tube of grease into it and still did not see any "peeking" out. Stopped at half a tube as I just knew the grease MUST be piling up somewhere and makin' a big mess. Rode the bike last night found no mess this morning so will add more today. It amazes me how empty the head tube comes from the factory.
2009 FLTR *Mirage Orange* / SE Heavy Breather / Fuel*Moto Jackpot 4" Dyno Tuned SLASH UP / PC-V / J&M 7.25 Speakers & Hidden Antennae
GRTSHRK is offline
post #8 of 9 (permalink) Old 10-07-2012, 02:14 PM
rageglide's Avatar
The factory only greases the bearings so that first greasing takes a ton... and just wait for a nice hot day... you'll have that crap oozing all over the lower tree and dripping down the left fork leg... think of it as rust proofing the front end. ;-)
post #9 of 9 (permalink) Old 10-07-2012, 05:41 PM
longrides's Avatar
"You need to crank bars all the way right and get very low to see the star nut..."
There's a little detail the manual missed..... no wonder I can't find it!
Currently Bikeless
Shopping for a '15 or '16 found one and it aint HD
2013 FLTRX Black Denim - 4" ceramic Jackpots, Fullsac X pipe header, PV w/FM map - gone but not forgotten
2008 Anniversary Edition,
gone but not forgotten.
longrides is offline
Adjust your Steering Head Bearing...easy hotrodad Tech Area 56 10-25-2013 06:43 PM
The way I tackled my steering head bearing adjustment. ironmark *General Road Glide Discussions/Pictures 16 10-09-2013 10:44 AM
Help with Steering Head Bearing Adjustment twistr Troubleshooting for Road Glides 15 07-23-2013 08:32 AM
Question on Greasing the Steering Head Bearing Teagatron3000 Do-IT-Yourself 32 04-13-2013 10:46 AM
steering head bearing adjustment question sgrooms Troubleshooting for Road Glides 10 03-28-2013 05:17 AM
