oil temp gauge issue - Road Glide Forums
post #1 of 5 (permalink) Old 10-08-2012, 04:47 AM Thread Starter
I have discovered that my oil temperature gauge, inserted in volt meter slot, shows the temperature when hot and the switch is turned off. Since the volt meter went off with loss of power, I am at a loss as to how the oil temp gauge can still work. And, since it does when hot, does it always drain power even when all the temperature is down to ambient and the switch is off. I always use a tender, but I am concerned if I may have a problem out on the road overnight. This is on a '09 CVO RG.
Anyone have an idea?
Bill in Stone Mountain
Bill Golightly is offline
post #2 of 5 (permalink) Old 10-08-2012, 06:30 AM
As long as its wired correctly it will be fine. It wont drain the battery.
post #3 of 5 (permalink) Old 10-08-2012, 07:36 AM
jimmyray11349's Avatar
If it is a Roger McEwen gauge that is normal. will not drain battery.
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
jimmyray11349 is offline
post #4 of 5 (permalink) Old 10-08-2012, 07:37 AM
If it is a Roger McEwen gauge that is normal. will not drain battery. don't
87hp 101tq
Baggershield
Saddlebag Bra
post #5 of 5 (permalink) Old 10-14-2012, 11:20 PM
bikepsych's Avatar
Are you sure it is still reading the temp or has it just stopped up there? I replaced my air temp gauge with the Rodger McEwan oil temp gauge and when I turn the engine off it does not return to "0." It stays where it was when I turned off the ignition.
BG
bikepsych, 2017 RoadGlide Ultra
Supertrapp Fatshots, SE A/C, 107 2 114 kit
bikepsych is offline
Fuel gauge, air temp gauge inop Crcarnage87 Troubleshooting for Road Glides 1 04-17-2017 06:19 PM
Engine oil temp? At what temp do you pull over? Mountainman Fluids and Lubricants 35 07-07-2015 03:47 PM
Oil temp gauge wanted (gauge only, not full kit" SickRick Wanted! (Buy or Trade) 0 04-08-2013 02:54 PM
Oil temp gauge bagger51 Aftermarket Accessories 13 03-02-2011 12:04 AM
Silver Face Oil Temp Gauge FLTRXS18 Classifieds Archive (3 months old+) 1 10-12-2010 10:00 AM
