Oil Change drain pan too big - Road Glide Forums
post #1 of 20 (permalink) Old 10-10-2012, 03:04 PM Thread Starter
Still Grumpy's Avatar
so... I just found out the oil drain pan that I have used for years on my ex Ultra will not slide under the RGC .....
Other than jacking it up (which would interfere with the placement of the pan anyways) what are you using when changing the fluids..?
I was thinking of using that same drain pan and cutting its height some.
I saw a LOW PROFILE drain pan that Harley sells. Wonder if it'll fit ..
Still Grumpy is offline
post #2 of 20 (permalink) Old 10-10-2012, 03:43 PM
PGR
PGR's Avatar
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Holds all 3 fluids with room to spare. Slides easily under the bike.
Ron..........................
PGR is offline
post #3 of 20 (permalink) Old 10-10-2012, 03:54 PM
OldNerdGuy's Avatar
One word of caution, do not leave it standing on end, full of oil, for any length of time, lest it bulge out on the bottom and become deformed. If you do not heed this advice, if you leave it out, flat, in the hot sun, open up one cap ever so slightly, push down on the bulging area to let all the air out, then seal it back up before air can get back in, you can get it reformed so it is back to it's original shape.
Ask me how I know this
Oh, and you can get this home on a Tour Pak Rack with a cargo net, just barely.
OldNerdGuy is offline
post #4 of 20 (permalink) Old 10-10-2012, 03:57 PM Thread Starter
HA HA ... YOU READ MY MIND.! I think I'll wait for the weekend and use my wife's car to go pick one up...
thanks !
post #5 of 20 (permalink) Old 10-10-2012, 06:37 PM
DC-3Mek's Avatar
Gotta say I LIKE that design! And $30 ain't bad!!! But I put my bike on a lift when I change the fluids.....
I might get it for the kid's Saturn.....
Now if you guys could just come up with a way to NOT make a mess pulling the filter.....!
DC-3Mek is offline
post #6 of 20 (permalink) Old 10-10-2012, 07:22 PM
11FLTRX103's Avatar
I cut a hole in the side of a larger oil jug didn't cost me a dime
11FLTRX103 is offline
post #7 of 20 (permalink) Old 10-10-2012, 07:23 PM
11FLTRX103's Avatar
harley makes a special funnel for that
post #8 of 20 (permalink) Old 10-10-2012, 07:26 PM
I have the one from HD also, it works great, and my bike is lowered. I refused to buy it because I thought it cost too much, my wife went and got it for me....I love that lady.
post #9 of 20 (permalink) Old 10-11-2012, 03:32 AM
HD_Shock's Avatar
I just use a cheap plastic pan from Walmart. Fits under the bike fine and cost about $1.50 I think.
Here ya go ...
https://www.roadglide.org/showthread.php?t=19339
-phil
2011 FLTRX 103
HD_Shock is offline
post #10 of 20 (permalink) Old 10-11-2012, 04:11 AM
Radioactive's Avatar
+1 on recycling. I used an old windshield washer fluid bottle.
Radioactive is offline
How often are you "supposed to " change the O-rings on the drain plugs MarkL *General Road Glide Discussions/Pictures 41 08-21-2017 07:44 PM
Oil Drain Plug Size (threads) JRB_RME5 Do-IT-Yourself 0 12-29-2014 08:28 PM
Low Profile oil drain pan danglide Do-IT-Yourself 6 12-13-2014 11:57 PM
Baker Plus One Oil Pan Tytanium Engine Related 0 05-17-2011 05:16 AM
