Mount & Change Rear Tire - Road Glide Forums
post #1 of 3 (permalink) Old 10-17-2012, 03:34 PM Thread Starter
jimmyray11349's Avatar
How difficult is it to mount a rear tubeless tire? 180/55B18. I do not have tire mounting machine. Is it worth the hassle? Do I need to get it balanced? If yes, do dina beads work?
Stealer wants $296 for tire plus $80 mount and balance. Seems high to me.
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
jimmyray11349 is offline
post #2 of 3 (permalink) Old 10-17-2012, 05:58 PM
staush's Avatar
Boy, you got that right(stealer), a lot of smaller shops are around $25 - $30 bucks to install new tire. You pull it off the bike. maybe thier price is pulling your wheel off . Then it's not a bad price.
staush is offline
post #3 of 3 (permalink) Old 10-17-2012, 06:58 PM
Roadie09's Avatar
I have mounted my own tires for the last couple of years. I will be honest, the 180/55-18 is probably the hardest tire out of any in the HD line-up.
The sidewall profile is low and the tire is stiff. I finally broke down and bought a cyclehill tire changer and that made the job unbelievably easy (at least compared to the old tire iron method).
You should be able to do the job, but for your first attempt you will have a challenge on your hands.
Roadie09 is offline
Lifters: to change or not to change BigNorm Engine Related 14 01-19-2016 07:50 AM
After Tire change rear break really hard?? motodrummer Troubleshooting for Road Glides 4 07-25-2015 10:38 AM
10" Windvest. front and rear turn signals. Rear mount and pegs and highway peg mount. 1346wildcat Parts for Sale 10 04-23-2013 06:34 PM
Time to Change Rear Tire Need Info!!! BadDadFLTR Wheels and Tires 2 03-19-2013 01:33 PM
Tire change = no rear brakes exammo Troubleshooting for Road Glides 11 10-12-2012 04:11 PM
