Add a Siren to your Factory Security for $6 - Road Glide Forums
 45Likes
post #1 of 483 (permalink) Old 11-02-2009, 03:45 PM Thread Starter
dklanecky's Avatar
Arrow Add a Siren to your Factory Security for $6
Ok, it'll be a little less than $6.
(Excuse the dirty bike.)
Works well, and is definitely cheap.
koryu2u, jnauert and DaleJ like this.
73 Sporty - Sold
07 Sporty - Sold
09 Vivid Black Road Glide (FLTR) with ABS, Security, Fuelmoto Satge One, Clearview, Harley Hammock Seat, Hogg Chopps Lowers, Bright Ass Tail Light, SERG Headlight Bezel, Detachable King Tour Pak, Painted Inner Fairing, Cruising Southeasten Wisconsin, Delivered 3/6/2009:clap:
09 Black Fat Bob (FXDF) in Vivid Black of course, Delivered 5/1/2009
dklanecky is offline
post #2 of 483 (permalink) Old 11-02-2009, 04:39 PM
CHAINSAW's Avatar
So where do the wires go?
Such is the rule of honor.
CHAINSAW is offline
post #3 of 483 (permalink) Old 11-02-2009, 05:40 PM
Admin
BillyBob's Avatar
No Photo????
BillyBob is offline
post #4 of 483 (permalink) Old 11-02-2009, 05:49 PM
SWFLGLIDER's Avatar
Dk.....does that reset automatically after a period of time ?
SWFLGLIDER is offline
post #5 of 483 (permalink) Old 11-02-2009, 05:51 PM
SWFLGLIDER's Avatar
Oops, what is the Radio Shack # for that part? I know they have a couple of different sirens, can't read it on the pic.......
post #6 of 483 (permalink) Old 11-03-2009, 05:39 AM Thread Starter
dklanecky's Avatar
The part number is 273-0079, and was $5.49. The factory security module has a plug to allow connection to the HD siren. I just tinned the two leads from the siren, and inserted them into the first two slots shown on the plug in the photo. Then I taped it up with electrical tape to see if it worked.
It chirps when you turn off the main power switch to the bike (at the same time the lights flash to indicate the system is armed). It alos then starts chirping a warning when the bike is moved (sounds a few times and then goes off full tilt).
I haven't left it on long enough to seee when it resets (it's pretty loud and I have neighbors), but I assume it operates the same as the flashing lights, they flash for a while and then reset.
koryu2u and maddmoe like this.
73 Sporty - Sold
07 Sporty - Sold
post #7 of 483 (permalink) Old 11-03-2009, 05:47 AM Thread Starter
dklanecky's Avatar
Here's a picture of where the plug sits (under the left side cover) for adding the siren, and the plug itself.
73 Sporty - Sold
07 Sporty - Sold
post #8 of 483 (permalink) Old 11-04-2009, 07:32 AM
wonbyone
Guest
Posts: n/a
I just wanted to add a little to this very good post for clarification...I did this yesterday... works very well. Loud too. Before doing this pull the main fuse. I have a 09 RG.
Red wire from siren goes to the brown wire on the Harley plug, and the black wire from the siren goes to the green wire on the plug. I just used a soldering iron to tin the siren leads to give them body to insert into the Harley plug. The Harley plug has 2 rows of pins, use the rows that do not have the metal visible when you are looking at the plug... look at it and you will see what I'm talking about. One row is connected to the wires on the back of the plug and the other is not. Once you get the wires inserted I then wrapped some electrical tape around the plug to keep the wires in place and re-inserted the plug back into the female receptacle on the chassis molding where it was originally stored. I drilled out the mounting holes on the siren to accommodate a wire tie(plastic zip tie) and secured it place where the OEM siren would go.
It chirps to warn you a couple of times and then goes off for about 20 seconds, then resets itself. If your Radio shack is like mine, the employees do not know what your are asking for and even after looking up the part number to confirm they had some, did not know where to find them. They are in the metal cabinets with sliding drawers. Easy.. good mod. --Bill
post #9 of 483 (permalink) Old 11-05-2009, 05:43 AM Thread Starter
dklanecky's Avatar
Bill,
Thanks for filling in the details! This is a simple mod, and I'm thinking I might go back and see if I can squeeze another siren in the same spot, for just a bit more noise.
73 Sporty - Sold
07 Sporty - Sold
post #10 of 483 (permalink) Old 11-05-2009, 06:50 AM
SWFLGLIDER's Avatar
I'm off to RS this morning...I hope that have that part here....most places now here only carry cell phone things , they did away with the metal bins
Security siren ? hawwk Tech Area 1 04-15-2018 09:11 PM
Security siren emptyking Do-IT-Yourself 11 05-23-2017 03:16 PM
Electronic Security Alarm Flashing and Security Alarm Chirping When Ignition Switch I aklowrider Troubleshooting for Road Glides 2 05-03-2016 02:26 AM
Finding and resetting Security Codes and Bipassing Security RICKLB58 Troubleshooting for Road Glides 0 03-26-2016 09:41 AM
Anybody add the Siren yet on the 15s FLTRXS18 Do-IT-Yourself 2 10-30-2014 12:59 PM
