inner fairing remova; - Road Glide Forums
post #1 of 7 (permalink) Old 10-26-2012, 11:54 PM Thread Starter
hi fo;ks i am new at this and was wondering if removing my inner fairing is a difficult job
bigtex is offline
post #2 of 7 (permalink) Old 10-27-2012, 02:25 AM
tatyou2's Avatar
Removing it isn't the difficult part, getting everything back together in the right place is the fun part.
Take a few pictures for reference as you are taking it off so you know where everything goes and you will be fine.
If it feels good, Do It!
tatyou2 is offline
post #3 of 7 (permalink) Old 10-27-2012, 08:40 AM
smitty901's Avatar
Just takes time and make sure you mark every thing some pictures also help.
And a place to put all the parts. Pulled forks while I was at it on this one
smitty901 is offline
post #4 of 7 (permalink) Old 10-27-2012, 10:18 AM
It is not hard to do and as mentioned before take a few pics it will help. The plugs on the wiring are plug specific which means that each plug is a different design so a male plug will only fit the correct female plug so these plugs do not need to be labeled unless you would like to. The gauge wires, turn signal and speaker wires are typical so you should label them to insure correct installation. If you are removing the instrument nacelle then you should label the speedometer and tachometer plugs as well.
post #5 of 7 (permalink) Old 11-09-2012, 03:09 PM
Dmize's Avatar
Do the cow bells come off without removing the forks? Cant tell from that pic.
Was planning on replacing mine this winter if it wasnt a HUGE task.
D.Mize
16 CVO RGU
Dmize is offline
post #6 of 7 (permalink) Old 11-09-2012, 03:58 PM
tmd
Taking almost anything apart is easy. The true test is seeing how many pieces you have left over when you put it back together.
tmd is offline
post #7 of 7 (permalink) Old 11-09-2012, 03:59 PM
tmd
Nope you have to remove the forks to replace them.
tmd is offline
Wanted Outer Fairing (possibly inner fairing as well) dimitri89 Wanted! (Buy or Trade) 4 02-19-2016 09:12 PM
OUTER FAIRING and INNER FAIRING Big Daddy Recon Parts for Sale 13 08-24-2014 10:42 AM
Inner Fairing Won't line up with the speedo. snapperkid Troubleshooting for Road Glides 6 03-30-2010 09:10 PM
need your opinions on my inner fairing mslater7412 *General Road Glide Discussions/Pictures 14 03-01-2010 09:38 PM
Want the Painted inner fairing, what year and model? RoadGlideBlues *General Road Glide Discussions/Pictures 9 10-23-2009 07:54 AM
