Reuseable Oil Filters - Road Glide Forums
 12Likes
post #1 of 20 (permalink) Old 11-02-2012, 07:32 AM Thread Starter
RGKen's Avatar
Anyone tried the reusable oil filters? If so, what do you think of them? Seems like it could be a cost saver if they work well enough.
http://www.mandmcycles.com/detail.as...uctNo=MM000372
2018 FLTRXS
RGKen is offline
post #2 of 20 (permalink) Old 11-02-2012, 07:39 AM
BDMastiff's Avatar
I looked into those a couple of years ago. I decided that I'm not a fan. HD filters are not expensive and they do a great job.
ironmark and eddienelson like this.
1996 Fatboy
BDMastiff is offline
post #3 of 20 (permalink) Old 11-02-2012, 07:52 AM
mmcmsw's Avatar
Hey shipmate
I run one on my RG. I have spent over 300 bucks (8 bucks each) putting oil filters on my Dyna, and like the one on my road glide. Heads up, when you order your filter, purchase a few of the seal rings. I have 11 oil changes on mine, and the seal ring will have to be replaced in the next couple of changes. If you ever buy a new bike, you can put the lifetime one on it, so it will be the last oil filter you ever buy. Mine was made by pegasus, but same design.
Trailers are for Boats!!
mmcmsw is offline
post #4 of 20 (permalink) Old 11-02-2012, 08:46 AM
DED HD's Avatar
Those seem very inexpensive! I always heard K&P were the best filters, and to be aware of chinese knock offs.
http://www.kandpengineering.com/
'10 Red Custom:
DED HD is offline
post #5 of 20 (permalink) Old 11-02-2012, 08:50 AM
CNMTurner's Avatar
Question for you guys that use these.
What solvent do you clean them with and is it a PITA and messy?
2010 FLTRX - Stage 4 SE 113 - MVA Heads, 10.5:1, SE266E cams, 58mm TB, 5.3 gr/s injectors, Polished and plated motor and trans and a few chrome extras. Fullsac DX Header and Freedom Performance Classic 4" Slip-ons. Titan II 6.5 speakers with RF PBR300x2, Monroe Airshocks
1996 Tail dragin' Fatboy
CNMTurner is offline
post #6 of 20 (permalink) Old 11-02-2012, 09:21 AM
mmcmsw's Avatar
They are easy to clean. Brake cleaner/similar, wipe, blow out with air. Not any more messy than disposal of old filter.
mmcmsw is offline
post #7 of 20 (permalink) Old 11-02-2012, 09:34 AM
chromedome's Avatar
Kinda seems like re-usable toilet paper to me.
Some things are just meant to be tossed....
2012 Road Glide Ultra (SOLD) & 2015 BMW R1200RT
chromedome is offline
post #8 of 20 (permalink) Old 11-02-2012, 09:34 AM
CNMTurner's Avatar
Thanks for the info.. I may look into them.. Always shied away thinking them a PITA to clean...
post #9 of 20 (permalink) Old 11-02-2012, 10:03 AM Thread Starter
RGKen's Avatar
Thanks for all the info brother! I may go ahead and get one as I have also been reading that they use these things on a lot of racing circuits because they actually filter crap out better than conventional. If you have run yours that long with no problem than I think it's worth a shot.
2018 FLTRXS
RGKen is offline
post #10 of 20 (permalink) Old 11-02-2012, 11:35 AM
DED HD's Avatar
Cleaning
We recommend the K&P Micronic Stainless Steel Oil Filter be cleaned frequently when first purchased or when engine work has been performed. This will give you a feel for how much debris is being filtered out of your machines oil and help you decide how often you want to clean the filter for your application. At minimum, clean the filter with every oil change. Remember, oil is the lifeblood of your machine, keep it clean!
Before cleaning, inspect the element and housing (spin on models) for debris. Since in nearly every case the oil flows from the outside of the filter to the inside, the debris will be caught on the outside of the filter element and on the magnet set into the top of the spin on models. Closer inspection of the debris can be achieved by flushing the particles into a clean light colored container. Monitor the debris from oil change to oil change. If something is significantly different in the amount or type of debris from the last cleaning or two, we recommend you investigate further.
Wash the reusable stainless steel filter element in clean solvent, gasoline, kerosene, aerosol carburetor cleaner or any other degreasing agent. You can even finish the cleaning process with some common dish soap and hot water. For stubborn debris, you can use a soft bristle brush to help dislodge particles from the screen. If you have compressed air available, blow air through the filter starting from the inside out, to remove any small particles or cleaning agent from the screen. If you don’t have compressed air, let the element air dry or use aerosol carburetor cleaner or something similar to displace the water. Finally, if you have a spin on model, clean the inside of the filter housing using the same type of cleaner as used on the reusable filter element.
Once clean and dry, you are ready to reassemble the filter unit, lube the quad ring with oil, and reinstall.
'10 Red Custom:
DED HD is offline
Re usable oil filters vs. traditional ODA CDR (RET) *General Road Glide Discussions/Pictures 15 03-20-2014 11:43 AM
Interesting Article on oil filters Cakeman1 *General Road Glide Discussions/Pictures 3 01-05-2013 05:26 PM
k&n oil filters skratch Equipment-RG 12 01-04-2013 09:53 AM
Anyone try these oil filters? 11FLTRX103 *General Road Glide Discussions/Pictures 36 09-08-2012 07:05 PM
High Performance Stainless Steel Micronic Motorcycle Oil Filters BDMastiff Engine Related 15 09-03-2011 10:19 AM
