Detachable tour pack for '13 Ultra? - Road Glide Forums
post #1 of 10 (permalink) Old 04-27-2016, 02:57 PM Thread Starter
Shadow Reaper's Avatar
i have a 2013 Ultra and would like to be able to remove the tour pack when not going on long runs.
can some one tell me if they know of a kit i can use to replace the hardmount?
Shadow Reaper is offline
post #2 of 10 (permalink) Old 04-27-2016, 03:22 PM
PGR
PGR's Avatar
H-D Detachables Tour-Pak Luggage Conversion Kit | Tour-Pak Accessories | Official Harley-Davidson Online Store
Ron..........................
PGR is offline
post #3 of 10 (permalink) Old 04-27-2016, 03:53 PM
SurlyBoy's Avatar
/\ That. Also get the quick disconnect wiring harness kit.
SurlyBoy is offline
post #4 of 10 (permalink) Old 04-27-2016, 03:54 PM
VikingRider's Avatar
OR you might consider this:
Patent-Pending Locking Tour-Pak Rack for 09-13 Touring Models
Motherwell Products are made in the USA. And this product retails at US$ 240-245,00 whereas the MoCo one cost about US$ 550,00. JMO
FLTRSEI2
VikingRider is offline
post #5 of 10 (permalink) Old 04-27-2016, 04:56 PM
the88virgnian's Avatar
I did the same for my 13 Ultra. Pieced together all of the parts from across the web and this forum. Saved a few hundred bucks that way over ordering straight from Harley. I would recommend not using the replacement harley license plate. I bought one from Kuryakan for like 20 bucks, and mounted it to the rear fender. Looks 10x cleaner.
As a side note, after installing the kit, I put the pack on and off for maybe a year. The past two years, the tour pack has remained on, as it the tour pack is extremely convenient for carrying stuff, even on short rides.
2013 RGU BBP. Detachable Tour Pack, aftermarket slip ons (no name), Wild 1 WO612s, Avon Cushion Grips, 13" Madstad, Kenwood Excelon x799, 8x DD Speakers (4x VO-M, 2x CXS 6.5, 2x B3), Diamond Micro 4v2 Amp.
the88virgnian is offline
post #6 of 10 (permalink) Old 04-27-2016, 05:14 PM
Bandit 7's Avatar
This is how I did mine as well and saved half not buying the kit. I also never take mine off. Should have just saved the cash.
Bandit 7 is offline
post #7 of 10 (permalink) Old 04-27-2016, 05:29 PM
Did my 13 Ultra. Aftermarket bracket and mounts. Speaker pods have a connector inside, roll the harnesses up under the seat. Made a quick connect with about 3 wires in it. Did the radio and CB antennas hidden in the fairing. Put speaker pods in the lowers so I had 4 speakers all the time. Saved enough with that and some dealer points that I got the CVO rear fender kit to mount the license plate. I do take mine on and off pretty often.
DuraGlide is offline
post #8 of 10 (permalink) Old 04-28-2016, 01:14 PM Thread Starter
you guys are awesome, thank you
post #9 of 10 (permalink) Old 04-28-2016, 01:57 PM
PGR
PGR's Avatar
You still have to buy the docking hardware to go on the bike. But I have seen these mounts, and they look nice.
PGR is offline
post #10 of 10 (permalink) Old 04-28-2016, 03:28 PM
Yes, good to point that out you'll need the following:
a) Antenna relocator kit OEM part: 76556-09.
b) Docking hardware (deutsch) OEM part: 54205-09.
Cheers!
FLTRSEI2
Ultra detachable tour pack ? Dennis Adams *General Road Glide Discussions/Pictures 9 07-14-2013 11:13 AM
Quick detachable tour pack mount jokercraze Sold 3 08-23-2012 09:30 AM
Tour Pack detachable brackets? Nukeleer Aftermarket Accessories 3 05-13-2012 11:41 PM
RGU detachable tour pack help needed oc357 Aftermarket Accessories 0 08-30-2011 04:22 AM
1999 ultra king tour pack off ultra EG used on a 2006 road glide?? kirkglide Aftermarket Accessories 2 05-30-2011 11:55 AM
