Fix a broken tab on inner fairing? - Road Glide Forums
post #1 of 16 (permalink) Old 05-09-2016, 10:37 AM Thread Starter
I noticed my right front speaker was flopping in the fairing so I took off the outer. I found that the top left plastic nubbin thingy(scietific name) broke off the inner fairing. I tried using some plastic weld epo epoxy and then clamping it with a c clamp to hold it untill it dried. How ever when I released the clamp this morning it broke off. I am thinking about going to the hardware store and getting one of those little nylon spacer thingys and drilling a little hole in my fairing and ptting a tiny screw thru that and the spacer with a nut to hold the speaker. What do you guys think? any other Ideas?
Bike is an 01 RG.
Lunchbox
2001 HD FLTRI
Lunchboxx is offline
post #2 of 16 (permalink) Old 05-09-2016, 10:53 AM
Bike is an 01 RG.
Not many choices for that. What you said or a new fairing. You might have to do all of them to match. Put up some pictures when done.
post #3 of 16 (permalink) Old 05-09-2016, 11:00 AM Thread Starter
Good call! All I could think of was how ugly its going to be. But if I use Stainless hardware and do all of them it may not look bad. Forget a new faring that sh&* is expensive and I am a broke ass.
Lunchbox
2001 HD FLTRI
post #4 of 16 (permalink) Old 05-10-2016, 09:28 AM
Keep a eye out for a used inner or call PC Pain and price a new inner. I don't think a stock inner cost too much.
post #5 of 16 (permalink) Old 05-10-2016, 09:57 AM
PGR
PGR's Avatar
Mutazu Vivid Black Inner Front Fairing for Harley Davidson HD Road Glide | eBay
Ron..........................
PGR is offline
post #6 of 16 (permalink) Old 05-10-2016, 05:41 PM
You know anybody who used one ? I wonder how it compares to oem ?
post #7 of 16 (permalink) Old 05-10-2016, 06:02 PM
PGR
PGR's Avatar
My wife has Matazu lowers on her 2008 RG. They are not bad. The hardware leaves a bit to be desired. But the main components are exact, right down to the OEM mold marks. So if that's any indication, for $200 bucks, you can't go wrong.
PGR is offline
post #8 of 16 (permalink) Old 05-21-2016, 09:20 PM
stackrat's Avatar
Try Bondic.
Bondic The worlds first liquid plastic welder. 4 seconds and fixed.
I've used it a few times so far and it really does work. All you do is put it on and shine the LED light on it for about 12 seconds. It's like the stuff the dentist uses to put crowns on (where the shine that blue light in your mouth to cure it). I got mine at Ace Hardware but I'm sure you can find it at Home Depot, Lowes, probably even Walmart.
2012 FLTRU - Ember Red Sunglo
2016 FLTRXS - Velocity Red Sunglo
>>> Apparently, I have a "thing" for redheads.
stackrat is offline
post #9 of 16 (permalink) Old 07-02-2016, 01:17 PM
Try this stuff. It works. I am not a spokesman for Plastifix. Simply a satisfied customer.
https://www.amazon.com/Urethane-Supp...ords=plastifix
larsfum is offline
post #10 of 16 (permalink) Old 07-05-2016, 05:47 PM
sfcusaret2004's Avatar
I can concur somewhat on this stuff. I have recently patched up a couple of cracks at the windshield mount holes . I am getting ready to redo two of the mounting tabs on the outer fairing so will see if it holds.
sfcusaret2004 is offline
Fix it or 2015? FIX! 08Zinc Engine Related 24 02-14-2017 06:26 PM
Help broken down & HD can't fix ameleo Engine Related 22 06-28-2016 12:22 PM
Corner of inner fairing is popped out. Looking for suggestions on a fix USMCEOD Paint & Bodywork Section 3 12-02-2015 08:17 PM
Broken tab on heat shield lundboy1 Intake and Exhaust 4 02-04-2014 11:34 PM
Crash Bar Broken at Top Tab harleson *General Road Glide Discussions/Pictures 6 07-19-2012 12:05 PM
