Rear brake peddle trimmed - Road Glide Forums
 8Likes
post #1 of 13 (permalink) Old 05-18-2016, 10:15 PM Thread Starter
Bbally's Avatar
As a 5'6" person I cannot have highway pegs way up on the engine guard.
I like them low and just about 7/8 the way up as the rear brake peddle. But the peddle is so wide it interferes with my feet on the long arm highway pegs,
I took the pad and pad cup off and front the hole is slotted for the pad mount.
The only thing stopping adjustment is the mounting steel the pad cup covers.
So I used the pad as a template and marked the support steel. Used a steel blade on the peddle to cut 5/8 inch off the outer edge. Remounted the brake peddle all the way in which give the clearance for my feet to rest on the pegs now.
SGMGrimsley likes this.
USMC 79-85
Bbally is offline
post #2 of 13 (permalink) Old 05-18-2016, 10:45 PM
Thats what you call good old fashioned redneck engineering. Glad it worked out for ya but it didn't really happen without pictures
post #3 of 13 (permalink) Old 05-19-2016, 06:20 AM
Smarty's Avatar
I took the pad and pad cup off and fount the hole is slotted for the pad mount.
On my old Heritage I took a Dyna brake pedal cover that was a lot smaller and removed the brake lever and cut the pedal down so the smaller pad would fit.. Got it out of the way and looked way better than the big ass pad that comes on them. Actually thinking of doing it to the RGS. Thanks for making me thinking about this again.
2016 RGS Black Quartz
Smarty is offline
post #4 of 13 (permalink) Old 05-23-2016, 08:18 PM Thread Starter
Bbally's Avatar
Ok pictures it is ...
If you are under 5'9" you probably hate trying highway pegs on the RG engine guard.
Because where you end up positioning them puts the right one interfering with the large brake pedal.
The answer to this is to remove the pad and use a jigsaw to cut off a half an inch arc the end.
This allows you to get clearance on the brake peddle by moving it on the slotted hole the brake pad goes through all the way to the left.
Allowing the whole set up to finally line up.
Of course the wife was not amused as she came out to the garage to see her husband sawing a piece "off the brand new motorcycle!"
Big_gary, 9over, Clutch1 and 1 others like this.
USMC 79-85
Bbally is offline
post #5 of 13 (permalink) Old 05-24-2016, 06:48 PM
9over's Avatar
Nice work
9over is offline
post #6 of 13 (permalink) Old 05-29-2016, 08:17 PM
Good idea! I have the same problem.
railer60 is offline
post #7 of 13 (permalink) Old 05-30-2016, 07:57 PM
Started this mod and ran into a very thick and hard chrome foot pedal. Jigsaw? I guess I need to find a better blade.
railer60 is offline
post #8 of 13 (permalink) Old 05-30-2016, 08:07 PM Thread Starter
Bbally's Avatar
Yes get a Bosch blade. Will tear right through it. About 11 bucks at Home Depot.
Make sure you get the one for hard metals.
Or if you know machining. 12 to 14 T per inch.
USMC 79-85
Bbally is offline
post #9 of 13 (permalink) Old 05-30-2016, 08:42 PM
Smarty's Avatar
A 4" cutoff wheel on a side grinder makes quick work of this. I cut it off, then used the grind wheel to shape. Then the emory wheel to smooth and finish. All of about 5 minutes total. Great improvement for foot position on the floorboard and highway peg.
Smarty is offline
post #10 of 13 (permalink) Old 05-30-2016, 09:09 PM
OK. Thanks
railer60 is offline
Brake Levers and rear brake pedal from 2010 FLTRX (STOCK) HUTMO Miscellaneous for Sale 4 03-03-2016 05:48 PM
Soft Brake chrome slotted Brake Pedal longrides Sold 7 05-17-2013 08:03 PM
Billet brake lever installed for rear brake HUTMO Do-IT-Yourself 1 12-27-2012 03:18 PM
Dual brake set up to single side brake Q-Hog Wheels and Tires 12 08-01-2012 11:55 AM
Changed rear brake arm now almost no rear brake? ncbeast Troubleshooting for Road Glides 4 05-30-2011 09:13 PM
