Installing 12V accessory charger in Tourpack - Road Glide Forums
post #1 of 13 (permalink) Old 12-25-2012, 08:12 AM Thread Starter
StriderJim's Avatar
I want to add an accessory plug in my tourpak for charging a laptop/tablet/phone while riding.
Looking for guidance, tips, etc. for doing this.
Do I just come off the battery and add an inline fuse?
How best to rout wires into Tourpak?
thx.
StriderJim.....................Blog:
StriderJim is offline
post #2 of 13 (permalink) Old 12-25-2012, 09:12 AM
The easiest way is to buy the kit. Not too expensive and pretty good instructions. That's what I did.
rdnkjeeper is offline
post #3 of 13 (permalink) Old 12-25-2012, 09:20 AM
faststan's Avatar
Wiring to connect to should be already in the bottom of the tour-pak. Install on the backrest bolts and plug in. Easy as pie......Note that this is a 'switched connection'........
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #4 of 13 (permalink) Old 12-25-2012, 10:51 AM
Triplej's Avatar
I got this idea from one of the other members here if memory serves me correct. The 12V Power Plug I used that can be purchased at Bass Pro Shops for a little more than half what the HD one cost. With some wire and connectors I keep on hand I had this one in just a few minutes using the same wires in the Tour-Pak that the HD version plugs into..
http://www.basspro.com/Marinco-Conne...product/23098/
Here are a couple pics of the finished product.
Triplej is offline
post #5 of 13 (permalink) Old 12-25-2012, 11:15 AM
1st Sgt's Avatar
Really? The wiring is already there - gonna have to take advantage of that!
1st Sgt is offline
post #6 of 13 (permalink) Old 12-25-2012, 08:22 PM
wenchal's Avatar
If you have the Ultra the pulg is already there. I had the HD kit from my previous bike, removed it before trade in. When i went to install in the new bike, discovered the plug was already there so just pluged in and there ya go.
wenchal is offline
post #7 of 13 (permalink) Old 12-26-2012, 01:59 PM
SurlyBoy's Avatar
Digikey sells basically the same outlet as the basspro for about $5
http://www.digikey.com/product-detai...S212-ND/755444
I used a bunch of them to add outlets to my truck. Also put one on my Nomad.
SurlyBoy is offline
post #8 of 13 (permalink) Old 12-27-2012, 01:52 PM
Fire-Medic's Avatar
Stupid question here, because I am installing my kit from HD today that was a gift from someone. I found the plug that is already there, but does that cable have the fuse inline already like the one that comes in the kit?
I plugged in the phone charger, turned on the ignition of the bike and it works, but want to make sure I do not damage anything. If this cable that's already there has a fuse inline then this is stupid easy, the hardest part will be cutting the liner for the TP.
FM
Fire-Medic is offline
post #9 of 13 (permalink) Old 12-27-2012, 02:02 PM
faststan's Avatar
Since it is switched it should be tied into the fuse block. I don't see a need for an 'inline' fuse.
faststan is offline
post #10 of 13 (permalink) Old 12-27-2012, 02:32 PM
Fire-Medic's Avatar
I agree, but the cable that came with the kit has an inline fuse, basically I just want to make sure this shortcut is not going to screw anything up is all. Not that big a deal to run the cable.
Gerbings T5 Hybrid gloves W/12V batteries and charger Perlinal Miscellaneous for Sale 0 02-27-2018 09:59 PM
Tourpack pad withouth tourpack dav.elis Seating: seats, backrests 6 10-03-2016 10:30 AM
2011 FLTRU up on stand...Install 12V Port in Tour-Pak Part 1. BLKNCr6 Road Glide Builds-Document your builds HERE --NEW 19 05-04-2016 04:13 PM
aero charger vs pro charger grindle19 Engine Related 9 10-27-2015 11:56 PM
Tour-Pak 12V acc outlet Runamuck Aftermarket Accessories 2 01-02-2011 03:46 PM
