Keeps blowing instrument fuse - Road Glide Forums
 2Likes
post #1 of 12 (permalink) Old 05-30-2016, 09:37 PM Thread Starter
Clutch1's Avatar
I have gone down the flow chart in the diagnostic manual and cannot stop my 04 from blowing fuses.
Found a short in the fairing, cleaned it up. Fixed the pin problem in the 12 pin connector. Changed the speedo. Keeps blowing the fuse.
Any other ideas?
Chuck
Clutch1 is offline
post #2 of 12 (permalink) Old 05-30-2016, 10:11 PM
Well it is a Canadian bike, and there is a mess of wires, they seem to fray at the center pull thru and color coding is hard to tell from brown to purple, I'd spect cutting a zip tie and checking for ground against the frame member
reds4 is offline
post #3 of 12 (permalink) Old 05-31-2016, 09:28 PM Thread Starter
Clutch1's Avatar
Thanks reds. I'll look deeper into the neck.
Clutch1 is offline
post #4 of 12 (permalink) Old 06-01-2016, 08:54 AM
After you make sure you have checked for shorts, you might try bumping the fuse size by one.
1982 FLT Virgin unmolested barn find.
1983 FXDG 80th Anniversary AKA Willie G Disc Glide, 10.5 to 1, Andrews B grind, 2002 Fat boy carb, Barnett Clutch, drag pipes.
2003 FLTSCI Black and Silver converted with Motor Trike Kit plus HD tour pak, 88 inch, HD 204 Cam, Vance & Hines mid shots.
AzHogRider is offline
post #5 of 12 (permalink) Old 06-01-2016, 09:07 AM
Going up in fuse size is not a good idea! Doing this will not fix the problem, one of 2 things will happen, either the oversized fuse will blow or if it doesn't blow there is a good chance that the wires will melt.
Obviously there is a problem, best way to find it is to unplug one accessory function at a time and see if the fuse does or doesn't blow. Remember just because the problem seems to be under the fairing it doesn't mean it is, there can be other locations such as down under the fuel tank in the wire tray for example.
A service manual has wiring diagrams that may help you troubleshoot this problem
post #6 of 12 (permalink) Old 06-01-2016, 09:30 AM
If you can watch it blow, you got some tracing to do
If ya go to the next 5 fuse up, could just smell trace
But not knowing what's been added, and you think no harm, but you know if you added more draw
Seen inside some where the wires are shaved wires to ck and leave bare
They made assorted candy fuses when they stopped wrappin gum in foil paper
We ant even going back to putting a copper penny in it
Shadow1 likes this.
reds4 is offline
post #7 of 12 (permalink) Old 06-01-2016, 11:35 AM
Generally one bump in fuse size will not burn up the wiring, like going from a 5 to 7 amp fuse. Higher resistance in the connections/wiring over time can cause fuses to blow. I certainly would not recommend a 10 amp jump in fuse size, more like a 20% increase should not cause a flaming wire. If it blows them you have got a short for sure.
post #8 of 12 (permalink) Old 06-01-2016, 05:21 PM
Free Willie's Avatar
Had the same problem on my 04.
On the front of the neck there is a small metal "post" I assume is a mounting point for wiring harness strap which on mine was never installed or broke and fell off. It rubbed through a wire and ground it out. Didn't want to remove inner fairing at the time so I was able to get an 1/8th inch thick piece of rubber in there to cover the post and got a wire tie on it. That was 3yrs and roughly 18000 miles ago and no more blown fuses. Hope this helps.
reds4 likes this.
04 RG Vivid Black
84 FLHS Shovel Flat Black & Flamed
Free Willie is offline
post #9 of 12 (permalink) Old 06-01-2016, 10:00 PM Thread Starter
Clutch1's Avatar
Thanks for the pointers. It's a 15 amp fuse in the instrument circuit. I will pull the fairing again and check all the wires deeper in the hole tomorrow. I've added nothing to the circuit but it does include the diagnostic part of the ecm.
Clutch1 is offline
post #10 of 12 (permalink) Old 06-14-2016, 08:59 PM
Srcobb's Avatar
I had to post because I just had the same issue on my 04. Turned out the problem was under the speedo and tach. There is a large bundle of wires that we're getting cut by the wind deflector that is bolted to the triple tree. I repaired the bad spot and tied the wire bundle to the side. No more problem. I hope that helps.
Srcobb is offline
Accessory fuse keeps blowing Clutch1 Troubleshooting for Road Glides 7 10-27-2015 02:40 PM
2007 RG keeps blowing 15A ignition fuse fxdlrider Troubleshooting for Road Glides 0 08-18-2014 05:53 PM
Blowing headlight fuse Countryboy Lighting 7 03-29-2014 05:04 AM
Keeps blowing turnsignal bulbs!!! Tim9339 Lighting 4 08-02-2013 08:40 AM
blowing ignition fuse drmudd Troubleshooting for Road Glides 4 07-31-2012 05:02 PM
