Inner Primary - Road Glide Forums
 2Likes
  • 1 Post By Dragon Dude
  • 1 Post By Lunchboxx
post #1 of 7 (permalink) Old 06-02-2016, 10:42 AM Thread Starter
Inner Primary
While removing my stator I decided I would upgrade to a Hayden M6 Primary chain tensioner. The OEM screws must have been put in with red lock tight I got the bottom one out but the top one will not come out. I try heat from a propane torch, I tried a chisel to turn it(after the screw stripped of course) and I have tried easy outs. Now I am thinking that drilling it out and putting in a helicoil is about my only option. Anybody got any other ideas?
Lunchbox
2001 HD FLTRI
Lunchboxx is offline
post #2 of 7 (permalink) Old 06-02-2016, 03:23 PM
FrankieB's Avatar
Heat the whole area around the screw then let it cool, do this a few more times. You want all the metal to expand and contract, this will usually break the bond of the Loctite. Then lastly pour the heat to the screw while you try to turn it. I prefer a heat gun for this instead of a flame.
06 RK
11 RGU
FrankieB is offline
post #3 of 7 (permalink) Old 06-02-2016, 03:41 PM
Dragon Dude's Avatar
I just bought a Baker Attitude adjuster and i hope i do not run into the kind of problems getting the bolts out as you have. I think i will go ahead and get me a heat gun before i start this project.
RFG7680 likes this.
Dragon Dude is online now
post #4 of 7 (permalink) Old 06-02-2016, 04:39 PM Thread Starter
I guess mine were put in with Red loctite They both Stripped out but I got the bottome one out and cant get the top out at all. Mine took a #4 phillips screwdriver. Good luck
Lunchbox
2001 HD FLTRI
post #5 of 7 (permalink) Old 06-03-2016, 09:28 AM Thread Starter
With patience, a little more heat and a different type of screw extractor I got it out!
FrankieB likes this.
Lunchbox
2001 HD FLTRI
post #6 of 7 (permalink) Old 06-03-2016, 10:40 AM
Alright, way to hang in there and getting the job done. I guess patience always pays off.
post #7 of 7 (permalink) Old 06-25-2016, 07:23 PM
sfcusaret2004's Avatar
Inner primary screw/bolts or outer primary? getting ready to replace my clutch spring, friction plates and steels and have already found that the dealer has stripped one of the inspection cover screws. would hate to botch the primary hardware, then try having the dealer cover those as well.
sfcusaret2004 is offline
Inner primary trim on an FLTRU HellInABucket Equipment-RG 2 11-25-2012 06:25 PM
Inner primary leaking 2000 FLTR Sealdoggy *General Road Glide Discussions/Pictures 7 06-07-2012 10:46 AM
inner primary bearing Jerry W. Engine Related 3 03-20-2012 12:15 PM
Inner primary cover chefskeeter Do-IT-Yourself 3 09-14-2011 09:05 PM
Inner primary seal vinchenz07 Troubleshooting for Road Glides 5 04-30-2010 10:00 PM
