Security Light comes on After Ape Instal - Road Glide Forums
post #1 of 4 (permalink) Old 06-04-2016, 01:30 PM Thread Starter
Installed new set of 14" malo's. Went relatively well. Bike starts , runs fine, all buttons work. After a few miles, red light comes on for security system and stays on. Checked security pin# and that is still correct, when bike is shut off, goes through normal security shut down. This is a 2015 RG. Any ideas?
eagleclaw is offline
post #2 of 4 (permalink) Old 06-04-2016, 08:29 PM
Check for codes and re-check ALL CONNECTIONS
post #3 of 4 (permalink) Old 06-05-2016, 07:49 AM
Neano62's Avatar
U frayed a wire sumwhere...uno slit it , and or cut thru ur wire insulation and the plastic stuff that's around it. does it again, stop and turn ur bars to the Left and the Right,...ur hitn wire to metal sumwhere!
[/IMG]
Neano62 is offline
post #4 of 4 (permalink) Old 06-16-2016, 03:08 PM Thread Starter
problem solved
when putting right grip back on, didn't get brake lever and switch aligned correctly, lever had no contact with switch. once this was corrected, light stays off.
no codes came up and everything worked fine. glad it was this simple and not a damaged wire somewhere.
Electronic Security Alarm Flashing and Security Alarm Chirping When Ignition Switch I aklowrider Troubleshooting for Road Glides 2 05-03-2016 02:26 AM
Finding and resetting Security Codes and Bipassing Security RICKLB58 Troubleshooting for Road Glides 0 03-26-2016 09:41 AM
Cant figure out how to instal my 6 1/2" speakers. Gasitman Audio 17 03-08-2014 04:40 PM
J&M Rokker XT/AMP instal along with IPOD interface Shark Bite Do-IT-Yourself 18 02-22-2013 09:43 PM
xm radio instal flper67 Do-IT-Yourself 5 10-08-2012 08:56 AM
