Slips in 5th gear - Road Glide Forums
 2Likes
post #1 of 16 (permalink) Old 06-21-2016, 09:35 PM Thread Starter
sfcusaret2004's Avatar
Wink Slips in 5th gear
40,000 miles on the 13 RGU and after the last service, she slips in 5th gear. wondering if it's time to replace the clutch plates. also looking at the AIM Variable pressure systems. Ideas from the peanut gallery?
sfcusaret2004 is offline
post #2 of 16 (permalink) Old 06-21-2016, 11:02 PM
Before you start replacing everything I'd suggest adjusting the clutch and see what happens. Not hard to do and it's free if you are able to do it yourself
post #3 of 16 (permalink) Old 06-22-2016, 12:13 AM
SurlyBoy's Avatar
Adjusting the clutch is easy. In addition to a new derby cover gasket you'll need an 11/16" offset wrench. It makes the job much easier. If you don't have one already you can swing by Home Depot and pick up a set for $25.
Husky MM Offset Double Box-End Wrench Set (5-Piece)-HDODBEW5PCMM - The Home Depot
The first time you open the lock nut it might be pretty tight from the factory. Put the bike in gear and put the front wheel up against a wall so it doesn't roll forward. If you can't get it up against something solid then have someone sit on it and apply both brakes. You can use a deep socket and breaker bar to open the nut but you'll need the box wrench to tighten it back up because you'll need to keep the Allen wrench on the adjuster while you lock it down
There's a couple of good videos on the ole 'Tube
SurlyBoy is offline
post #4 of 16 (permalink) Old 06-22-2016, 07:45 AM Thread Starter
I thought about that but since it's only slipping in 5th, wasn't too sure adjusting it would help. Might give it a try, though if the suggestions don't prove helpful. I guess a better question is, How much mileage should one expect to get on the factory clutch, accounting for average riding, average weight, and steady throttle hand? Hoe long did your OEM clutch last and how did it fail?
post #5 of 16 (permalink) Old 06-22-2016, 08:05 AM
Smarty's Avatar
Before it slips anymore, buy you a screaming eagle diaphragm spring. It will solve your problem if you haven't glazed your plates. Worth a try and a cheap fix.
2016 RGS Black Quartz
Smarty is offline
post #6 of 16 (permalink) Old 06-22-2016, 08:44 AM
Smarty is right, it won't get better, only start to wear down.
The so called "diagram places positive pressure on pack enabling
full power transfer, lack of is that slip and must be dealt with.
I've replaced a few, and metrics too........
Ok, from spanking nrw never have even adjusted the clutch and it's Never sliped
In our 03 flt (100k+), if it did I'd at least put another SE on top the basket, you should ck your frictions and clean your steals while your sitting on your staring at it, not many beer of a job...oh and I've been using the same gasket from go, never a leak
reds4 is offline
post #7 of 16 (permalink) Old 06-22-2016, 09:37 AM
PGR
PGR's Avatar
I'm at 65,000 on my 2011.
I agree with the suggestion to open the derby and adjust it. If that fixes it, you saved some money to use on other things.
Ron..........................
PGR is offline
post #8 of 16 (permalink) Old 06-22-2016, 02:30 PM
SurlyBoy's Avatar
I've wondered about that. The original gasket looked fine when I first took it off. I've replaced it both times I've opened the primary but I've put seals and gaskets back on bikes with really sketchy service history. I think I'm going back to the rubber one next time and leaving it on a while. Even if it starts to weep a little it's pretty easy to find another and replace it.
SurlyBoy is offline
post #9 of 16 (permalink) Old 06-22-2016, 02:57 PM
PGR
PGR's Avatar
I have 65,000 miles on my bike. I'm still using the original rubber "O" ring gasket. No leaks.
rlaf75 likes this.
PGR is offline
post #10 of 16 (permalink) Old 06-22-2016, 03:15 PM
Hamrhead's Avatar
Slipping in 5th
I had noticed the same thing after my last fluids change and clutch adjustment. I had noticed some minor slipping after having a good dyno done, but would just do a clutch adjustment and all seemed ok.
I just ordered the Screamin Eagle clutch spring, will install that when i get the chance and go from there. From what Ive read and gathered from others this should fix the slipping. From the looks of it, it can be accomplished through the derby cover with out removing the outer primary?
Smarty likes this.
2013 FLTRX B B P, 11 in Paughco RG Apes, V & H Monster Round, American custom dual header, SE high flow air intake, 8.5 in Klock Werks shield, Monotubes up front, lots of blacked out chrome parts, and the list goes on.......
Hamrhead is offline
DYNO RUNS 4th or 5th GEAR? ChivoChavez321 Fuel Moto 8 02-26-2014 06:02 PM
5th gear slip WILLIAMJRDN Troubleshooting for Road Glides 12 01-01-2014 03:48 PM
5th gear cruising SilverGhost *General Road Glide Discussions/Pictures 35 06-29-2012 06:01 PM
5th gear lewintennessee *General Road Glide Discussions/Pictures 14 05-30-2012 08:42 PM
5th gear slip???? SafetyMan Road Glide Specific Discussions 8 11-14-2010 05:38 PM
