Why wood eye even consider it - Road Glide Forums
 7Likes
post #1 of 37 (permalink) Old 06-22-2016, 11:45 PM Thread Starter
A stabilizer system for my Roadglide?
I mean don't you/they or have been taught? TO
check your wheel bearing And your Swing Arm bearings
EVER SINGLE TIME a rear tire replaced?
And how are you checking the Swing Arm with it Nutted Up with a Brace?
Ant it just masking up, or is it a Crutch for your limpness?
Energy has to transfer, what is being Stressed or released
to in its place.
I hear some 'Riders say they can feel the added vibration
on the straight aways.....thru the frame
Don't see many keeping up with us loaded and 2-up in the switches
Or sweepers
are the stabilizer more like a back brace?
Once bitten twice shy?
Didn't they do away with bushings '03 and up?
reds4 is offline
post #2 of 37 (permalink) Old 06-23-2016, 01:09 AM
nsbohall's Avatar
Why wood eye even consider it, coming from you reds, I don't know if that's rhetorical or a real question. I'll stay tuned for the responses.
2013 FLTRU, S&S Power Tune Duals, Supertrapp Stouts, Andrews 48's, AN Big Sucker, Direct Link, Fuel Moto LED's, Custom Dynamics, 14.5 Madstad, 14" Carlini's, Legends AXEO and Revo A's.
nsbohall is offline
post #3 of 37 (permalink) Old 06-23-2016, 06:17 AM
Smarty's Avatar
Personally since they went with the new frames and motor mounts in 09 I don't know why you would even consider the stabilizer. If you want to stiffen it up some in the swing arm area, use the Glide Pro bushings and that will take out what slack you may find when the belt tugs on the swing arm. The motor mounts and hiem style motor supports do a really good job of keeping the motor alignment in place. The weak point being the swing arm. Since I put the Ohlin shocks on the back of mine, going over double the speed thru sweepers is a piece of cake. No bobble, no correcting, just stays planted on the correct line chosen thru the corner and the exit is smooth as glass.
2016 RGS Black Quartz
Smarty is offline
post #4 of 37 (permalink) Old 06-23-2016, 06:39 AM
Reds got a 03.
I never had any problems with the oem set up on my past Evo Ultra's. I always rode them like baggers , and not like Ninja's.
post #5 of 37 (permalink) Old 06-23-2016, 07:16 AM
'05Train's Avatar
The new frame didn't change the important thing; the engine's still missing a rear stabilizer, which means that the swingarm will still move laterally when laying over in a sweeper under power. A True-Track will keep the rear of the motor/transmission in place and nearly eliminate the movement that gets the swingarm moving side-to-side.
Good shocks certainly help, but push the bike hard enough and it'll still wobble.
Singlebeam and bigr545 like this.
'05Train is offline
post #6 of 37 (permalink) Old 06-23-2016, 08:23 AM Thread Starter
Oh, there will be a 'firepit Keeper (from my Sailor' days), indeed.
after or in between.
Retoilit able? What dat, and why woodya take it back out.....try flushing twice......., Hollywood? ? sht
So if the Service Mgr comes back & says
" your Swing Arm bearing are fine" how did they figure so fast?
reds4 is offline
post #7 of 37 (permalink) Old 06-23-2016, 10:20 AM
JacktheBagger's Avatar
Shipmate , ewe aint sta- bil , therefour dew knogit a sta- bil eye zer
2011 Ultra
JacktheBagger is offline
post #8 of 37 (permalink) Old 06-23-2016, 10:35 AM Thread Starter
Still no get it? The stabilizer holds no true weight (w tf that is)
I understand the lateral force, the bolted shocks support the Swing Arm and provide the rail affect in motion
Guess I am asking "aren't the bearing design for race (pun)
reds4 is offline
post #9 of 37 (permalink) Old 06-23-2016, 03:01 PM
'05Train's Avatar
Not sure what you're getting at. Of course they don't hold weight. And of course you disconnect it to check the swingarm bushings.
'05Train is offline
post #10 of 37 (permalink) Old 06-23-2016, 03:30 PM Thread Starter
Guess what Iam getting at, auuuu
The rubber type Isolators act like bushings (sacrificial)
So ya take the plastic chrome plugs out to see if there's
any distortion? As an early waring sign?
RGKen likes this.
reds4 is offline
Consider making 2:1:2 DragoBikeWorks Intake and Exhaust 21 11-01-2013 12:00 PM
Things to consider when looking for a windshield Peppa1 Windshields 4 10-22-2012 12:03 PM
Wil also consider trades...my Kerkers jim_b Classifieds Archive (3 months old+) 4 04-01-2012 09:25 PM
Why? Why? Why? CMS *General Road Glide Discussions/Pictures 16 04-11-2011 01:46 PM
