Derby Cover Questions - Road Glide Forums
post #1 of 19 (permalink) Old 01-07-2013, 03:38 PM Thread Starter
Skid1's Avatar
I got a new derby cover for Christmas, and was going to put it on myself. Only thing is I don't have a lift or jack to keep the bike upright. Any suggestions or tips from the experienced wrench spinners? Also the torque settings would be about 8-9 lbs/lbs right?
Skid1 is offline
post #2 of 19 (permalink) Old 01-07-2013, 03:39 PM
Peewee's Avatar
A 2x4 under the kickstand works pretty well, or a buddy that you trust
Sent from my DROID RAZR using Motorcycle.com Free App
"Know Thyself"
Peewee is offline
post #3 of 19 (permalink) Old 01-07-2013, 03:56 PM
skratch's Avatar
you don't really need that. there shouldn't be that much oil in there, and if there is, it's overfull. just on the off chance that it is, put something under there to catch any overflow so you don't get your floor dirty.
now, for some random thoughts in no particular order:
is it hd or aftermarket? if hd, it should have a groove in it for the quad ring. if aftermarket, you'll need to get the pancake gasket.
do you have new screws? why put the crappy zinc screws back in if you have a nice shiny cover? torx or allen, doesn't really matter (some say it does, but i've not had a problem with the torx screws in over 10 years and i've removed my derby a whole bunch of times)
make sure you use a t27 on the torx and not a t25. otherwise you'll be drilling the heads off the screws.
make sure the torx bit is engaged in the screw as far as it will go, and hold it straight while you turn it so you don't strip the heads.
use a small dab of anti-seize on the new screws and don't overtighten them, 8-9 ft/lbs is about right. tighten them in a star pattern, and don't do the final tightening until they have all been tightened some, keeps the stresses even. if you want to use a torque wrench, go for it, but not really necessary. it is not high pressure behind it, so a little snug is good. really tight is bad.
i'm sure someone else will chime in with something i forgot.
skratch is offline
post #4 of 19 (permalink) Old 01-07-2013, 04:03 PM Thread Starter
Skid1's Avatar
Skratch- Thanks for the tips. It's an aftermarket and I have the flat gasket for it. I think the stock bolts will be fine for the cover (see attached photo).
You mentioned anti seize, but why not locktite?
Skid1 is offline
post #5 of 19 (permalink) Old 01-07-2013, 04:59 PM
I scraped the torque head screws for allen screws and I am a lot happier with them. Don't use anti-seize use yellow or blue lock tight, the derby covers from HD come stock with yellow lock tight on the new screws but if you go with the allen head screws you can use blue lock tight. I have had the derby cover screws loosen up due to vibration after doing a fluid change and not using lock tight.
post #6 of 19 (permalink) Old 01-07-2013, 05:33 PM Thread Starter
Skid1's Avatar
Thanks for the tips. No oil leaked when I took the cover off, now the same can't be said for putting it back on .
Here she is on. Small victory for the mechanically challenged.
Just for future reference, where would I get the different bolts at?
Skid1 is offline
post #7 of 19 (permalink) Old 01-07-2013, 05:49 PM
Dmize's Avatar
Looks great Skid!
D.Mize
16 CVO RGU
Dmize is offline
post #8 of 19 (permalink) Old 01-07-2013, 06:12 PM
HellInABucket's Avatar
Looks great! Suggestion - look for some black allens at Ace hardware...
2020 FLTRK
Roll away the dew...
HellInABucket is online now
post #9 of 19 (permalink) Old 01-07-2013, 08:41 PM
Radioactive's Avatar
Looks great!!!
Radioactive is offline
post #10 of 19 (permalink) Old 01-07-2013, 09:43 PM
Deb
Deb's Avatar
I like it!
2013 Road Glide Custom, ABS, security, cruise, vivid black, C and C solo, Fat Mini Apes, D & D Fat Cat w/ Stage 1 SEPST, Black Daymaker, LED turn signals with triple play...work in progress
Deb is offline
New Derby/Fuel Door Cover/Timing Cover - D&L Derby Cappers REDRUM *General Road Glide Discussions/Pictures 4 06-09-2014 05:52 PM
Derby Cover / Air Cleaner Cover Jetman Parts for Sale 9 09-08-2013 03:57 PM
Solo seat, BN bag liners, derby cover, primary cover SIC_26 Classifieds Archive (3 months old+) 15 12-27-2012 05:06 PM
Derby Cover specs triple buzz Aftermarket Accessories 6 08-21-2010 09:13 AM
