Outer Fairing Screw Mount Issue - Road Glide Forums
 3Likes
post #1 of 13 (permalink) Old 06-28-2016, 09:22 PM Thread Starter
Bleachey's Avatar
So I notice the left side of my windshield and outer fairing vibrating like crazy as I'm getting off the interstate on the way to work. When I get into the parking lot I notice a little more gap between the inner and outer, pull on the outer a little bit and it's not secured any longer. The screw in the inner is still there. It looks to me from the little gap I can pull out that the outer fairing is broken and the screw isn't attached to the outer anymore. Of course there isn't a torx that fits on the tool kit Harley gives you. I talked to Hoosierboarder and he agrees something is very weird. I stop by his house after work because he's an expert at taking fairings off and sure enough the, I don't know what you call it, "cone" I guess, where the screw threads into is broken off the left side. It's starting to crack on the right side. The service guy at the dealership wasn't sure if ESP would cover it. The finance guy sent me the ESP contract instead of me digging through my files to find my copy so I will be reading it next to see if it is possibly covered. Haven't heard of this happening before. I could see stripping the threads out since they are plastic, but it's definitely not over torqued. I've attached picture to try and illustrate, I'm not a very good photographer, but I think you can see the issue.
2011 Road Glide Ultra
Bleachey is online now
post #2 of 13 (permalink) Old 06-28-2016, 11:58 PM
EODHOG's Avatar
Send a message via Yahoo to EODHOG
That sucks. You might check with some local body shops and see if they will squeeze you out some panel adhesive. They use it to bond body panel together. It would just take a pea sized drop to put it back together. Let it cure for 24 hours and you should be back in business.
Good luck. Tell us how you make out, Bleachy.
Freedom isn`t free. If you can read this, thank a Teacher. If it`s in ENGLISH, Thank a VET! The right to keep and bear arms shall not be infringed.....
EODHOG is offline
post #3 of 13 (permalink) Old 06-29-2016, 04:16 AM
Roysant's Avatar
Both the left and right side of my 2011 have broken. ESP says it is not covered, some bull about it not being a bracket. I have taken the fairing off and have attempted to repair it with crazy glue and JB weld. The left side has held up about a year now. The right side I just did yesterday.
Roysant is offline
post #4 of 13 (permalink) Old 06-29-2016, 06:59 AM Thread Starter
Bleachey's Avatar
My buddy's neighbor, who is a paint and body guy happened to get home as we were looking at it. He said they have epoxy, and some wire mesh stuff they use. He was going to look to see if they had some scraps and leftover epoxy laying around since it is such a small area. It's hidden when properly installed so it doesn't really matter what it looks like. I'm going to go ahead and reinforce the right side as well. Looks like my weekend project is scheduled, after I finish the boys brake line tonight.
post #5 of 13 (permalink) Old 06-29-2016, 11:35 AM
This is a common failure point. It occurs when the outer fairing is not EXACTLY lined up with the inner fairing. People get it close then suck it up using the screws, which works for a while, but eventually the stress is too much, and you get what you see here. You must make sure the outer fairing screw holes are lined up and fitting properly up to the corrosponding screw hole on the inner fairing before installing the screws. This is not always easy. I have found that if you pop out the headlight frame then re-& installing the fairing on the hook, then carefully push the fairing around until both sides fall into place. There are little plastic pieces which hold the fairing from fitting correctly so you have to mess with it untill it drops into the correct position. The last thing you want is to drag it into place using the screws. Just my experience from doing it a few times.
Illegitimus non carburundum. Or something to that effect. Jack of all trades, master of none.
Diverrick is offline
post #6 of 13 (permalink) Old 06-29-2016, 12:31 PM Thread Starter
Bleachey's Avatar
Thanks for the info. Not sure if this is the cause, although I did have the outer off a few weeks ago. Don't remember it not lining up properly, will be extra careful to not do it after the repair.
post #7 of 13 (permalink) Old 07-02-2016, 01:08 PM
I had one of the ferrules crack in half, and the piece fell off, lost forever. I tried the JB weld trick, but it also broke rather quickly. I google foo'ed fix abs fairing, and found PlastiFix. This stuff is the shite! Easy to do. Sets up in 10 minutes.
https://www.amazon.com/Urethane-Supp...ords=plastifix
larsfum is offline
post #8 of 13 (permalink) Old 07-02-2016, 01:54 PM Thread Starter
Bleachey's Avatar
This is on my to do list today. Taking a break now from working on the brakes on my truck, then this or audio installation on my softails is next. It's supposed to be rainy tomorrow and Monday so I'm not in a hurry. I have to get the brakes done today because the truck won't fit in the garage. Turned down two offers to ride today, but I have to get this shit done. Maybe we will ride to dinner tonight. I hate being a grown up and acting responsibly.
Big_gary, TroyAK and JG762 like this.
post #9 of 13 (permalink) Old 07-03-2016, 11:42 AM
It seems that once the plastic is broken any fix will not last.
The good news is you can get a brand new HD painted outer fairing from Jon (PC Pain) for under $400 shipped to your door.
post #10 of 13 (permalink) Old 07-03-2016, 02:14 PM Thread Starter
Bleachey's Avatar
At that price I might have to explore that option.
Cross threaded screw on Outer Fairing-Advise? geo8866 Do-IT-Yourself 16 10-01-2018 06:16 AM
Outer Fairing screw hole stripped motosig102 Paint & Bodywork Section 37 08-02-2016 10:47 PM
Broken outer fairing screw post? Driftah Troubleshooting for Road Glides 7 08-12-2014 10:36 AM
Tour Pak Speaker Pod screw/barrelnut issue GermanyBert *General Road Glide Discussions/Pictures 5 08-16-2013 02:54 PM
strange inner fairing screw issue jcmer22 *General Road Glide Discussions/Pictures 11 05-09-2013 04:57 PM
