clutch cable adjustment - Road Glide Forums
post #1 of 15 (permalink) Old 01-14-2013, 04:50 PM Thread Starter
My 07 RG has a bit of slack in the clutch lever. Everything feels and functions ok, but the lever when released it doesn't go fully to seat I have to just bump it abit to seat.
ORANGERG121 is offline
post #2 of 15 (permalink) Old 01-14-2013, 04:58 PM
Triplej's Avatar
May be time for a clutch adjustment. Here is a link of a video showing the procedure. Make sure the bike is cold before attempting. I usually let mine sit overnight before adjusting the clutch.
http://www.youtube.com/watch?v=Zl92wwLiNwE
Triplej is offline
post #3 of 15 (permalink) Old 01-14-2013, 05:01 PM
+1 on the clutch adjustment.
post #4 of 15 (permalink) Old 01-14-2013, 05:15 PM
Make sure you leave some free play where your cable enters the perch. it's not supposed to be socked up tight.
SickRick is offline
post #5 of 15 (permalink) Old 01-14-2013, 05:37 PM
JJSW1283's Avatar
1/8 in per service manual. My lever doesn't go all the way back either. Not sure if it's supposed to or not.
JJSW1283 is offline
post #6 of 15 (permalink) Old 01-14-2013, 06:09 PM
Triplej's Avatar
Another thing that helps is to lube the cable regularly to keep things moving freely.
Triplej is offline
post #7 of 15 (permalink) Old 01-14-2013, 06:14 PM
Lube
What do you use for lube? uhhhh...I mean for the clutch.
mpowered is offline
post #8 of 15 (permalink) Old 01-14-2013, 06:26 PM
Triplej's Avatar
I prefer Dri Slide.......... at least for the cables
http://www.jpcycles.com/product/900-...FSWoPAodtAoA-Q
Triplej is offline
post #9 of 15 (permalink) Old 01-14-2013, 09:15 PM
DO NOT put any lube on your clutch cable!! The cable is neoprene coated and doesn't require lube. Lubing the cable will cause the dirt to collect and gum up inside the cable and cause cable failure. My 08 has never had any lube in the clutch cable and it works just like a new clutch cable. You need 1/8 inch of play in the clutch lever, this is to make sure that the clutch is fully engaged when riding.
post #10 of 15 (permalink) Old 01-14-2013, 10:10 PM
Triplej's Avatar
Sorry to disagree with the ironmark but my owners manual says otherwise.
Triplej is offline
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
Need Help-Clutch Cable Lever Change-Tight Cable SNemet Controls & Handlebars 6 04-28-2016 05:42 PM
Clutch cable replacement/adjustment Nchoman Tech Area 5 11-19-2012 10:45 AM
Clutch adjustment procedure aviaator Road Glide Specific Discussions 13 07-28-2011 03:38 PM
Clutch adjustment longrides Do-IT-Yourself 5 09-23-2010 10:51 AM
