Needs another rotor - Road Glide Forums
 2Likes
  • 1 Post By Darreldanger
  • 1 Post By MightyWhitey
post #1 of 7 (permalink) Old 07-19-2016, 11:02 AM Thread Starter
Darreldanger's Avatar
Needs another rotor
Gettin tired of replacing parts over and over, now one of my front brake rotors is warped again (.006) out. (I replaced the rotors about 1.5 years ago). And now HD does not stock the raw agitator rotor that I have any more meaning if I want them to match I get to buy 2 new ones. I also just replaced my regulator again about 1 week ago...Nice. And no the pads are not dragging.
brokerthanu likes this.
Darreldanger is offline
post #2 of 7 (permalink) Old 07-19-2016, 11:13 AM
Are you using floating rotors?? I put floating rotors on my 08 4 or 5 years ago and haven't had a problem since. I used HD floating rotors but there are aftermarket options too.
As a side note I am not one that uses the front brake much, I look ahead and start to slow down early if I can and I downshift and use the rear brake in my controlled stops. I only use the front brake when I need the extra stopping power.
post #3 of 7 (permalink) Old 07-21-2016, 08:52 AM
Phantom6722's Avatar
I hear ya. I'm on my third set of rotors (floating) last December I had to replace the front set on my 09 CVO; the left one was warped but got both replaced using ESP.
Cheers Skip
Phantom6722 is offline
post #4 of 7 (permalink) Old 09-25-2016, 09:12 AM
gorillaman's Avatar
My 2016 has warped rotors at 7,000 km's. They are floaters . Anyone know the best replacement??
2016 FLTRU Vivid Black
gorillaman is offline
post #5 of 7 (permalink) Old 09-25-2016, 10:21 AM
MightyWhitey's Avatar
Don't take this the wrong way I'm not trying to be an asshole by correcting here but I think some folks are confusing floating rotors with semi-floating rotors. Semi-floats have friction rings bolted to the center mount. Full float are loose riveted to the center mount. Harley doesn't know what a floating rotor is. if it's a floating rotor you will be able to grab the outer ring and move it around. It will rattle. That's a full float. Too many companies hard rivet a rotor and call it floating. I think it's like calling something "made in America" if at least 51% of e components are assembled here. Just a lie really. If you want full floating rotors you'll probably have to look somewhere like galfer or brembo.
Zog likes this.
MightyWhitey is offline
post #6 of 7 (permalink) Old 09-25-2016, 10:44 AM
gorillaman's Avatar
I get what M-W is saying...
I'm just looking for something with more meat on the bone. The stock ones look like spoked wheels...??
post #7 of 7 (permalink) Old 10-23-2016, 08:00 PM
1extremeskier's Avatar
Went with Lyndall floating on my 2013 and have been very happy. Looks great and stops real well. Very little dust also
1extremeskier is offline
Needs another Volt Regulator Darreldanger Tech Area 9 07-16-2016 08:37 PM
Help Needs with TBW Donk *General Road Glide Discussions/Pictures 4 03-15-2011 08:31 PM
Virgin at Daytona Bike Week needs help? Seven3smoke Road Trip Discussions/Stories/Pictures 14 02-02-2011 06:51 PM
New bike needs attitude! dblkick *General Road Glide Discussions/Pictures 16 07-14-2010 06:51 PM
New user needs help with engine SLBERRY427 Troubleshooting for Road Glides 10 06-28-2010 07:24 AM
