Replaced Fried Stator, Volt Regulator 15 RG.... - Road Glide Forums
 4Likes
post #1 of 14 (permalink) Old 07-31-2016, 12:44 AM Thread Starter
maddmoe's Avatar
Replaced Fried Stator, Voltage Regulator 15 RG (Pics)....
...thats right a few weeks ago i boosted my baby after it died on me down in the village, from 2 cars ....i should not have had the cars runnings but i was at a lost ( had a Goldwing for 7 years never had one battery issue with the OEM battery )..... anyway make a long story a little shorter, i realized my bike was running off of just the battery and decided that i should have long time ago upgraded to the 54 Amp High Output Charging Kit from Harley since i have alot of toys on my baby, so thats what i just did part #29900028A.....I also added the New Battery from Yuasa GYZ32HL ( 500 Cold Cranking Amps ) and once i was done and I started her back up and i thought she was going to blow up while i was sitting on her, she felt strong, to me at least lmao....
......OH AND IM ONLY SHOWING MAJOR PARTS DURING THIS INSTALL, to get this far you should already know about removing floor boards etc etc etc
REMOVE YOUR BATTERY POST TO BEGIN
DRAINING PRIMARY CHAINCASE FLUID AND REMOVING THE COVER
ADDING TIE WRAP AROUND CHAIN TENSIONER AND REMOVING 2 BOLTS
HERE YOU HAVE TO REMOVE THE , RETAINING RING, RELEASE PLATE & LOCKNUT WHICH TURNS CLOCKWISE TO LOOSEN
YOU WIL WILL ALSO NEED A LOCKING TOOL TO LOCK THE GEARS TO REMOVE THESE BOLTS
THIS SIDE YOU JUST NEED A T70 BIT
THIS WILL REMOVE AS ONE
YOU HAVE TO REMOVE THE 2 BOLTS FOR THE STARTER AND REMOVE
VikingRider likes this.
Dont talk about it, Be about it !!!
maddmoe is offline
post #2 of 14 (permalink) Old 07-31-2016, 12:45 AM Thread Starter
maddmoe's Avatar
THE REST WAS REMOVING THE BOLTS TO GET TO THE STATOR
SO THIS IS WHAT I WAS LOOKING FOR, LOOKS LIKE SOME BURNT CHICKEN
AH SO NEW SO PRETTY ( Bet you i wont burn this one up )
AND BACK TOGETHER AND RUNNING GREAT
maddmoe is offline
post #3 of 14 (permalink) Old 07-31-2016, 01:39 AM
The Volusianator's Avatar
Either you're a mechanic or you got balls the size of coconuts. Either way, congratulations on a job well done!!
Wade
macabra11 likes this.
The Volusianator is offline
post #4 of 14 (permalink) Old 07-31-2016, 07:22 AM
Ohiobellboy's Avatar
Great job on the pix and all. I'm guessing MoCo dumped what was left of your warranty due to all the modifications?
A.K.A OBB
Ohiobellboy is online now
post #5 of 14 (permalink) Old 07-31-2016, 08:43 AM
Good Job! I am just curious in why you removed the inner primary because the stator R&R can be done without removing the inner.
post #6 of 14 (permalink) Old 07-31-2016, 11:19 AM Thread Starter
maddmoe's Avatar
Wade
Thanks but im not a mechanic, ive always just been good with tools and good at remembering how to break things down and put em back together again BUT i do buy a shop manual with every Bike i buy and cars too
maddmoe is offline
post #7 of 14 (permalink) Old 07-31-2016, 11:22 AM Thread Starter
maddmoe's Avatar
Wouldnt know about the warranty , i wouldnt trust them or anyone else for that matter, working on my baby
maddmoe is offline
post #8 of 14 (permalink) Old 07-31-2016, 11:28 AM Thread Starter
maddmoe's Avatar
Just following the shop manual, hopefully i wont have to do this again !
maddmoe is offline
post #9 of 14 (permalink) Old 07-31-2016, 11:45 AM Thread Starter
maddmoe's Avatar
The best part of this install is NO harley bill at the end, my pockets feel much better
maddmoe is offline
post #10 of 14 (permalink) Old 07-31-2016, 01:01 PM
Clutch1's Avatar
Nice work. Especially on the no bill part. I don't trust too many to work on mine either. The shop manual is a must for all vehicles I own.
maddmoe likes this.
Clutch1 is offline
Cycle Electric 3 phase 50 Amp Stator, Rotor and Regulator Upgrade 2000roadglide Do-IT-Yourself 12 08-26-2017 11:07 PM
Needs another Volt Regulator Darreldanger Tech Area 9 07-16-2016 08:37 PM
voltage regulator or stator? Swagzilla Troubleshooting for Road Glides 0 07-17-2012 11:57 AM
While I was getting my voltage regulator replaced.... BigDeez *General Road Glide Discussions/Pictures 16 06-26-2012 06:25 PM
stator/regulator dddboat Troubleshooting for Road Glides 8 04-03-2012 06:30 PM
