Clutch adjustment ?? - Road Glide Forums
  • 1 Post By 1st Sgt
post #1 of 10 (permalink) Old 01-26-2013, 09:47 AM Thread Starter
1st Sgt's Avatar
So I've adjusteed my clutch a few times since getting the bike and it alwasy seems to be rather abrupt engagement - I'm sure it can be adjusted to have a smoother engagement but in order to do that, do I need to tightern the adjusting screw a little bit more or loosen it just a smidge?
RoadGlideGary likes this.
1st Sgt is offline
post #2 of 10 (permalink) Old 01-26-2013, 10:11 AM
Ironrider's Avatar
Re: Clutch adjustment ??
There are videos on you tube that shows exactly how to adjust it.
Sent from my MB860 using Motorcycle.com Free App
Ironrider
Ironrider is offline
post #3 of 10 (permalink) Old 01-26-2013, 10:15 AM
have you tried different fluids in the primary? maybe it's the type of oil in there? Might make a difference going to primary oil,atf,etc.
danglide is offline
post #4 of 10 (permalink) Old 01-26-2013, 10:17 AM
Ironrider's Avatar
The. Engagement is your transmission I use amsoil transmission oil. I understand that redline maybe even better because it sticks or adheres better. They bikes do engage like that. My 2 cents
Ironrider
post #5 of 10 (permalink) Old 01-26-2013, 10:46 AM Thread Starter
1st Sgt's Avatar
Well I've reviews the video, the guidance in this forum and even read the instructions in the manual - and I'm following the procedure correctly. os that seems to be consistent. I did just change the oil last night and am switching from HD Forumla+ to Redline Primary oil. Haven't ridden it yet with the new brand of oil but will follow up on this thread whether or not I can tell a difference. Thanks for all the input.
1st Sgt is offline
post #6 of 10 (permalink) Old 01-26-2013, 11:21 AM
Ironrider's Avatar
Do your tranny oil your primary is fine unless its slipping
Ironrider
post #7 of 10 (permalink) Old 01-26-2013, 11:29 AM
Brent376's Avatar
Redline Shockproof
JAWZ 2 / 2015 RGS /Custom Paint
Brent376 is offline
post #8 of 10 (permalink) Old 01-26-2013, 11:55 AM
I only adjust my clutch if it feels out of adjustment. If your clutch feels good and normal then there is no need to adjust, when I did the clutch adjustment the first few times I seen that the clutch never needed adjustment so I don't mess with it to often now. The book says to turn the set screw out 1/2 to 1 full turn so I just split the difference and go 3/4 of a turn and my clutch works fine. But if you are in there and it make you feel better then go ahead and check the adjustment of your clutch.
post #9 of 10 (permalink) Old 01-28-2013, 07:03 PM
Originally Posted by Brent376 View Post
Redline Shockproof
Plus one on the Red line Shock proof gear oil for the tranny.
Big_gary is online now
post #10 of 10 (permalink) Old 01-28-2013, 07:31 PM
Mike U's Avatar
I'm definitely a believer in Red Line Shock Proof.
Been using it for years, in the trans, with much success.
I also use Red Line Motor Oil and Primary Oil.
Very happy with their products.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
2012 clutch adjustment cloud Tech Area 4 07-18-2012 09:37 AM
Clutch Adjustment jimmyray11349 Troubleshooting for Road Glides 4 07-02-2012 12:38 PM
Clutch Adjustment Tool JayKS Do-IT-Yourself 12 06-01-2012 09:40 PM
Clutch adjustment procedure aviaator Road Glide Specific Discussions 13 07-28-2011 03:38 PM
Clutch adjustment longrides Do-IT-Yourself 5 09-23-2010 10:51 AM
