Stripped Inner Fairing Screw Hole - Road Glide Forums
  • 1 Post By rideon
post #1 of 9 (permalink) Old 08-24-2016, 06:40 PM Thread Starter
the88virgnian's Avatar
I keep running into stripped inner fairing screw holes. I've repaired it twice with JB weld, and the issue keep rearing its head. Saw once before, someone had purchased metal sleeves that go inside the screw holes and are threaded. Anyone got leads on that?
the88virgnian is offline
post #2 of 9 (permalink) Old 08-24-2016, 06:51 PM
Coming loose?
I have one stripped hole that I put a couple toothpicks in when I put it back together. Holds tight.
Jayray is offline
post #3 of 9 (permalink) Old 08-24-2016, 07:47 PM
UT_Larry's Avatar
I used 60 sec epoxy in the hole, placed in the nut. Then hammered in a couple of fine stainless steel brads, then cut flush. No further trouble.
UT_Larry is offline
post #4 of 9 (permalink) Old 08-24-2016, 10:38 PM
The Volusianator's Avatar
Inner fairing screw holes?
The Volusianator is offline
post #5 of 9 (permalink) Old 08-24-2016, 10:47 PM
rideon's Avatar
Check to make sure the screws are in the right holes. The two lower ones are longer than the rest.
BlueBagger12 likes this.
2018 Road Glide Special, vivid black
rideon is offline
post #6 of 9 (permalink) Old 08-24-2016, 11:54 PM
This along with trying to close the fairing gap of a mis-aligned fairing by tightening the screws to tight are the common reasons they strip. I use a good quick dry apoxy to repair the ones I've stripped. Works great for me
post #7 of 9 (permalink) Old 08-25-2016, 07:41 AM
hoosierboarder's Avatar
Got this at Home Depot. Works great!
hoosierboarder is offline
post #8 of 9 (permalink) Old 08-25-2016, 08:30 AM
My repairs with SEM or just using JB thin with tequila have held,
with skilled application and jigging the outer fairing with old leathers and curing till the tequila wears off, works.
It would be just as easy to take the brass nurrel from those
squish wellnuts and shorten the threads, drill and set, then use stack washers on the
outside of the inner. Thus sleevin
reds4 is offline
post #9 of 9 (permalink) Old 08-25-2016, 08:44 AM
rideon's Avatar
I've had my fairing on and off a lot and all the screw holes are fine. I think the secret is just gently snug, the screws are in plastic they won't back out. I've heard the tooth pick trick works quite well.
rideon is offline
Outer Fairing screw hole stripped motosig102 Paint & Bodywork Section 37 08-02-2016 10:47 PM
Fairing attachment screw stripped out. Straitline Troubleshooting for Road Glides 11 08-10-2014 12:49 PM
Stripped Fairing Screw Hole EasternSP Paint & Bodywork Section 10 09-13-2012 10:40 PM
Fairing screw hole repair tomerza Paint & Bodywork Section 19 04-26-2012 09:18 AM
Stripped screw METIME Troubleshooting for Road Glides 13 10-24-2010 04:36 AM
