09 no cat header on a 2013 - Road Glide Forums
post #1 of 7 (permalink) Old 01-30-2013, 06:52 AM Thread Starter
jack6hd's Avatar
What's involved for this switch? Is it possible? So far I know the OS's are bigger and the plugs for them are 2 prong vs 4 and the locations are different. Reason for the switch is tuning. I already got the pipe w/shields at a swap meet last week for $45. If the switch is too involved, I sell the pipe and go with plan B.
2015 FXDL 2nd best HD on road
jack6hd is offline
post #2 of 7 (permalink) Old 01-30-2013, 07:11 AM
It will fit right up .i'm running a 09 head pipe cause I run a thunder max tuner which has the large o2 sensor.
Jetworks is offline
post #3 of 7 (permalink) Old 01-30-2013, 07:14 AM
Sorry forgot to mention it on a 2012 .
Jetworks is offline
post #4 of 7 (permalink) Old 01-30-2013, 07:16 AM
93-331-29psi's Avatar
The swap shouldn't be to difficult, however as you stated the o2 bungs are different sizes. The location shouldn't be too much of an issue as there is some slack in the wiring which should accommodate.
93-331-29psi is offline
post #5 of 7 (permalink) Old 02-13-2013, 09:45 AM
Chiselhead's Avatar
Let's see, how to explain. The O2 sensors are different size and type. 09 is broad band versus 12 narrow band. To reinstall your original sensors you will need to drill a couple holes in the 09 head pipe and have a couple of bungs welded in. You will need to plug the holes (18mm) up near the heads. These bungs can be bought cheap and a custom exhaust shop should be able to install them if you don't have the means to do so. The smaller (14mm) sensors need to stay in the stock location unless you are running a controller that autotunes using the wide band sensors. Hope I didn't confuse you or get anything wrong there. I took a buddys 09 pipe and welded in the bungs.
2012 RGC Denim Black, Fuel Moto Stage 1, De-Catted Exhaust, Reinhart 4" Slip Ons, Dyno Jet Powervision
1965 Electra Glide 84" Shovel Top End, Leimweber Cam, S&S Super B
Chiselhead is offline
post #6 of 7 (permalink) Old 02-13-2013, 10:15 AM
Rkfltrx's Avatar
An easier thing to do IMO is to just gut the catalytic converter out of the original head pipe. It's pretty easy to do and there are posts on here that show you how to do it. If you don't want to do it yourself I have an extra 2010 head pipe that I can decat and sell it to you for $85 if you ship me yours back $140 if you don't ship yours back. Just PM me!
SOLD:
2012 FLTRX Denim Black,Stock head pipe with Cat removed w/ Jackpot 4" black slash up slip-ons. power vision, Fuel Moto pro billet A/C, Woods TW-222's, 12" Klock Werks . Sanchos Wings. Khrome werks 2+2 Handlebars.
Rkfltrx is offline
post #7 of 7 (permalink) Old 02-13-2013, 10:55 AM
you're all set if you decide to go with a tuner,like a thundermax that uses wideband o2's.The stock sensors might work if they were adapted to screw in and the wires were rerouted,or else you could weld in some of the small o2 bungs down close to stock location.
I'm running a pipe for an 09 on my bike,bolts right up.
danglide is offline
2016 FLTRU - CAT or no CAT ? gorillaman Intake and Exhaust 23 08-07-2016 04:20 PM
No cat 2013 head pipe BigWaterJim Parts for Sale 2 03-10-2015 04:56 PM
09+ Tour Pak Mount (53411-09) and Side Covers (L-47526-09, R-47522-09) bikerglasses Parts for Sale 3 12-06-2013 09:33 AM
Stock 09 Headpipe No Cat Chiselhead Parts for Sale 2 10-15-2013 07:43 PM
2009-2013 Cat free header Toecutter Sold 3 05-28-2013 01:13 PM
