iPod interface for RGU - Road Glide Forums
post #1 of 3 (permalink) Old 02-04-2013, 09:05 PM Thread Starter
BklynRGU's Avatar
For a RGU the iPod interface is a little easier. It comes with the 35 pin connector and the only empty spots in the connector is for the interface wires.
This the back of the radio 35 pin connector is on the right.unplug and take all the tape off and wire tie it will make it easier when installing the pins
This is the back of the connector the white pins are the seal pins and those are the ones u remove with needle nose pliers and the iPod interface wires go in just follow the instruction for the kit.
2016 RGS
2011 rgu brillant silver-sold
BklynRGU is offline
post #2 of 3 (permalink) Old 02-04-2013, 09:22 PM Thread Starter
BklynRGU's Avatar
In some sites they say u dont have to remove the the red plastic lock on front of connector i did could not get pins pushed in this pic is how I put the wires again remove the electrical tape and wire ties make it easier to push pins in.
On the RGU there is a 6pin connector on the left side(this is if u are looking at the front)this is a male female connector in the iPod interface wiring kit u connect the male and female ends together.
2016 RGS
BklynRGU is offline
post #3 of 3 (permalink) Old 02-04-2013, 09:23 PM Thread Starter
BklynRGU's Avatar
Then all u do it hook up the ipone/iPod and pray it works lol
2016 RGS
BklynRGU is offline
Problem with ipod Nano and/or HD iPod Interface wingman05 Audio 29 09-17-2014 07:48 AM
Replacement iPod cable from Boom Audio iPod interface kit McGruder Audio 7 04-21-2014 05:08 AM
Ipod HD. interface needed if one uses J&M NEW Ipod interface??? hogger Audio 2 10-22-2013 02:28 PM
HD Audio iPod Interface Install - 2011 RGC wachuko Do-IT-Yourself 26 12-31-2012 07:30 PM
Boom!™ Audio iPod® Interface? Not_A_CVO Audio 30 04-22-2012 09:21 AM
