Same old speaker question... - Road Glide Forums
post #1 of 16 (permalink) Old 02-06-2013, 07:28 AM Thread Starter
dmiller's Avatar
Hey guys,
Looking to add a rf pbr300x4 amp, 2 of the rf 6.5 slims in the inner fairing and replace the factory speakers. Im thinking the j&m (i think) 7.25 that were just reviewed here recently. Besides an amp install kit and speaker wire, do i need anything else for this? I assume the factory hk has rca outputs on the rear? How about adapter rings? Do the 7.25 speakers come with them? Anything else i need to consider? Or anyone know where to get the best prices on this equip? Thanks in advance
Sent from my DROID RAZR using Motorcycle.com Free App
dmiller is offline
post #2 of 16 (permalink) Old 02-06-2013, 09:08 AM
Going to try to answer a few of your questions:
1. The 300x4 is a 4ohm amp, the JM speakers are 2ohm. The speakers will work, but not recommended. You would be better off with 2 300x2 amps in your situation, the 300x2 is 2ohm stable.
2. The JM speakers do come with adapters.
3. The OEM HK radio does not have RCA jacks and if you are going to use the RF amp you wouldn't want to use them anyway.
Best prices will probably come from e-bay or a dealer, not the factory.
If you do go with JM, the Rokkers would be worth the extra investment if you are going to use an amp.
Read through some of the audio threads, there is a lot of advise on set ups, and a lot of people that will be willing to help you. Do you have a $$$ amount you are targeting? What you are willing to spend, and the sound you are looking for mean a lot. I hope this helped.
D. Bell
post #3 of 16 (permalink) Old 02-06-2013, 09:14 AM
Speedie's Avatar
This seems like a dumb question but I can't find a thread or post that addresses .... besides the less than optimimum sound coming from the rear, what would be the downside of boosting the front speakers with an amp and leaving the rear speakers un-amplified?
2015 Road Glide Special
Detachable Trunk : Detachable Passenger Back Rest
Rinehart Exhaust : De-Cat Headers : J&M 330W Rokker Amp and Speakers
Speedie is offline
post #4 of 16 (permalink) Old 02-06-2013, 09:18 AM
Not a dumb question at all. You would basically have less volume from the rear, easily adjusted with the fader, if you ride solo most of the time, it's an economical way to get more sound in your face.
post #5 of 16 (permalink) Old 02-06-2013, 09:20 AM
Speedie's Avatar
Perfect! Thanks!
Speedie is offline
post #6 of 16 (permalink) Old 02-06-2013, 09:27 AM Thread Starter
dmiller's Avatar
Re: Same old speaker question...
Thanks dbell,
Money is always an issue and this isnt my top priority. Im just looking for a bit better and louder than the stockers can offer. I liked the rf amp for the price so buying 2 of the 2 channels is a little much. I guess here is the big question...what 4 speakers can i buy that offer a decent quality, preferably at or under 100 a pair, that will not require losing my gloveboxes and can stand up to rain? I may get the speakers and buy the amp later when money is available. How does the rf amp hookup to the factory hk if not by rca? Line level output and do i need a converter or preamp in that case? Thanks again
dmiller is offline
post #7 of 16 (permalink) Old 02-06-2013, 09:39 AM
You can still buy the thin RF speakers for the inner fairing. I had a set of Polk MM651's when I had the RF 300x4, they worked great. The Polks are 2.7 ohms, not 4 but didn't seem to cause too much harm to the amp, (I don't think I would try it at full volume for a long time). You would hook the RF amp to the speaker output of the HK radio on the high level input. No converter or preamp needed, just adjust the input. Also you would need to run a power and gnd to the amp, not a big deal.There are several reasonanbly priced 4ohm 6.5" speakers that will fit in the fairing with adaptors. Keep checking Hawgwired, if you can get a set of there 4 ohm speakers that would be nice, every now and then they have an open box special.
post #8 of 16 (permalink) Old 02-06-2013, 10:50 AM Thread Starter
dmiller's Avatar
And are there 2 versions of the rf t165 speaker? A thin and a regular? I see them on ebay but some are 70 buckas and some are 150. Whats the difference? Anyone have a good link? I think id like to stay away from the polks if the impedance doesnt match. Ill look up the other ones though.
dmiller is offline
post #9 of 16 (permalink) Old 02-06-2013, 01:19 PM
There are 2 versions, T-165 should be the ones your looking for, S usually means (shallow), but I believe RF uses it for their component speakers. Just make sure you don't get the T1675, they will not fit....ask how I know. Go to the RF site look it up and then do a search, they can definetly be had for around $100 or less.
post #10 of 16 (permalink) Old 02-07-2013, 06:28 AM Thread Starter
dmiller's Avatar
These here are shallow enough so i wont have to cut my gloveboxes?
http://www.amazon.com/gp/aw/d/B0076S...sr=8-1&pi=SL75
dmiller is offline
How old is too old maddogdrury General Off-Topic Discussions 26 10-01-2013 11:50 AM
New cam same old tune? Reddobe1 Engine Related 7 08-08-2013 03:55 PM
hey all same old story sanddragonslayer New Members Welcome Area 56 04-21-2013 06:45 AM
Old is new again, caused by being old... petewerner New Members Welcome Area 49 02-19-2013 09:46 AM
Another same old leak Redfish-Joe Troubleshooting for Road Glides 12 12-28-2010 09:19 PM
