Grip intstall - Road Glide Forums
post #1 of 11 (permalink) Old 02-07-2013, 01:29 PM Thread Starter
Grip intstall
Does anyone know how difficult it is to change grip on an 09 RG with TBW?
billporter135 is offline
post #2 of 11 (permalink) Old 02-07-2013, 01:57 PM
FrankieB's Avatar
Slide off slide on, use a skinny screw driver in the left one to loosen it if need be.
06 RK
11 RGU
FrankieB is offline
post #3 of 11 (permalink) Old 02-07-2013, 02:03 PM
Paul's Road Glide's Avatar
hardest part is probably going to be not losing the screws and taking off the clutch side grip (b/c it's glued).
Paul's Road Glide is offline
post #4 of 11 (permalink) Old 02-07-2013, 07:19 PM
RoadGlideRider's Avatar
I thought that the new left grip is now a "Slip On" grip. The older ones were glued on the handlebar.
RoadGlideRider is offline
post #5 of 11 (permalink) Old 02-07-2013, 07:40 PM
NorCal's Avatar
my 2013 FLTRX left side grip was glued on....
NorCal is offline
post #6 of 11 (permalink) Old 02-07-2013, 07:44 PM
It may just appear glued. Did you soak it in hot water.
I found that if you do, the grip will slip off.
post #7 of 11 (permalink) Old 02-07-2013, 07:45 PM
Grip intstall
Just slice it off, not worth anything anyway.
mirage orange 09, 21" chrome PM Heathen, 8" klock werks, 17" apes, arnott air, J&M rokkers, dresser duals with high output slipons. custom dynamics accent lights, Battistini wireframe everything
citified is offline
post #8 of 11 (permalink) Old 02-07-2013, 08:22 PM
Ironrider's Avatar
it is really easy to do you should have it done before you read this note
Ironrider
Ironrider is offline
post #9 of 11 (permalink) Old 02-07-2013, 09:09 PM
My 2012 was slightly glued and now my avons are for real glued on.
post #10 of 11 (permalink) Old 02-07-2013, 09:48 PM
elbohead's Avatar
If your question is regarding running the TBW internally, it can be a bit of a PITA. I have HeliBars so only a portion of the TBW is inside. There is a post on this forum by a member named Donk. I followed his instructions in his first post where the wiring was all external and it was a huge help. I think he has another post where he shows how to wire internally. If you're only installing grips it should be simple. You just have to make sure the grips you buy are designed for TBW and they'll practically install themselves.
2012 FLTRX, BBP, 13" MadStad, Fuel Moto Pro Billet AC and 4" Dyno Tuned Jackpots, catless header, DinoJet Power Vision, Horizon Helibars, Iron Aces mount, HD Aileron grips, Ward's cooling fans, Mustang Wide Tripper solo, CD Plasma Rods and LED turns...
elbohead is offline
Iron Aces Rushmore Road Glide Mount w/X-Grip and RAM Finger Grip Bunker Parts for Sale 6 04-06-2017 01:24 PM
New Daymakers - Can't Wait to Intstall Them eme56 Lighting 11 02-07-2014 03:24 PM
Mini Apes & Hand Grip Wind Protection? Tek74 Controls & Handlebars 22 01-11-2011 03:59 PM
Heat Demons grip warmers? dres22 Controls & Handlebars 7 12-04-2010 08:02 PM
Odd grip question. cem1133 Aftermarket Accessories 9 06-04-2010 07:18 PM
