Clutch Cable Play - Road Glide Forums
 2Likes
  • 1 Post By 71Surfbs
  • 1 Post By Hillglide
post #1 of 3 (permalink) Old 10-22-2016, 06:29 PM Thread Starter
Clutch Cable Play
I have a 2007 Road Glide 18,000 miles, I changed the stock clutch and plates to a Barnett set without issue. This is the second time I changed the primary fluid and was beginning to adjust the clutch. When I screwed the cable adjusting nut together to allow play I ended up with about an inch and an eighth (1 1/8) of play at the lever and can`t seem to adjust it out after screwing in the adjusting screw in and backing off a half turn. I have tired both backing out less and more but the cable adjustment still seems to much, like it has stretched or something has come undone?
I have tried searching posts, nothing came up the addressed this issue that I could find.
I thought adjusting the shovel was difficult...
Thanks,
Harry
Rough Idle likes this.
71Surfbs is offline
post #2 of 3 (permalink) Old 10-22-2016, 07:08 PM
https://www.youtube.com/watch?v=59oe54UWOWU
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #3 of 3 (permalink) Old 10-22-2016, 07:29 PM Thread Starter
Thanks for the reply, I reviewed several "how too" adjust videos prior to attempting and have had no problems the last three adjustments. This time when I screw the cable adjust nut all the way in, adjust the diaphragm screw and nut, I have too much cable to come up with an 1/8 to 1/4 inch at lever. The adjustment screw comes out of the sleeve nut?
Thanks for replying
HDS
71Surfbs is offline
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
Clutch Play in Cable 71Surfbs Do-IT-Yourself 3 12-04-2016 02:55 PM
Need Help-Clutch Cable Lever Change-Tight Cable SNemet Controls & Handlebars 6 04-28-2016 05:42 PM
Braided Clutch Cable Repair? hdmagic Troubleshooting for Road Glides 1 08-15-2010 06:30 AM
Clutch cable clip on side of gauge housing GizmoGlide *General Road Glide Discussions/Pictures 8 03-26-2010 12:00 PM
