want to change to Streetglide rear Fender - Road Glide Forums
 6Likes
  • 2 Post By MightyWhitey
  • 1 Post By Big Spoon
  • 1 Post By ironmark
  • 1 Post By bucketlisthd
  • 1 Post By rlaf75
post #1 of 9 (permalink) Old 11-20-2016, 03:18 PM Thread Starter
I would like to change from my stock RG Ultra Rear Fender to a Tri Bar Street Glide Fender. has anyone done this? The standard Tail Light is not on the Streetglide Fender so I'm wondering if there will be problems with the plug under the seat matching up or if a new loom can be ordered. Both are 2012.
swampking is offline
post #2 of 9 (permalink) Old 11-20-2016, 05:42 PM
Bandit 7's Avatar
You can add the tri bar facia to your 2012. I did it and so has several others on here. Much easier than replacing the fender unless your trying to get rid of the big taillight. Search the threads for rear facia install. There are a few with part numbers and instructions. Good luck!
Bandit 7 is offline
post #3 of 9 (permalink) Old 11-20-2016, 06:09 PM Thread Starter
Yes I do want to get rid of the Tail Light. Just trying to figure out the if I will have a connection problem for the lights. The Fender replacement is not a big deal
post #4 of 9 (permalink) Old 11-20-2016, 07:15 PM
MightyWhitey's Avatar
You can get a new harness with the lights you want. And if you want a vivid black tri-bar light fascia that you can paint whatever color you like, I just happen to have one I pulled off my original 13 fltrx fender that I gave to a friend. I'll make you a great deal if you promise in the future to call it a roadglide custom fender...not a streetglide fender.
08Zinc and Big Spoon like this.
MightyWhitey is offline
post #5 of 9 (permalink) Old 11-21-2016, 01:58 AM
Big Spoon's Avatar
After the first of the year I'll have the stock fender off a roadglide special to go with MightyWhitey's tribar. It has the bullet style taillights instead of the big tail light. If you want to go that way.
MightyWhitey likes this.
"If you're gonna be dumb, you gotta be tough"
2008 FLSTF Fatboy
2017 FLTRXS Roadglide Special
Big Spoon is offline
post #6 of 9 (permalink) Old 11-21-2016, 05:59 AM
Getting rid of the rear taillight may make the rear of the bike look better but it also decreases the visibility of the rear of the bike to other motorist . As a safety stand point the more lights in the rear of the bike the better. JMO
bucketlisthd likes this.
post #7 of 9 (permalink) Old 11-21-2016, 07:13 AM
bucketlisthd's Avatar
I was never a fan of the HD fender tailight. However, I didn't think it looked too bad on my '09 with a razor tour pak. I ended up converting the bike to CD lights. The tailight got a smoked laydown lens. It looked pretty good, and I'm a big fan of plenty of lights. Getting crushed from behind while looking stylish is not my idea of fun.
VikingRider likes this.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is online now
post #8 of 9 (permalink) Old 11-21-2016, 12:07 PM
+1 I like it now. With the CD magic strobe everything flashes together. Added a Kuryaken laydown plate above the taillight to get rid of the billboard. Came out nice, just have to drill three holes.
2013 Ultra
Pics here:
rg_dave is offline
post #9 of 9 (permalink) Old 11-21-2016, 05:55 PM
The fenders are the same with the exception of the gaping hole where the big brake light mounted to it. And of course the color. My 09 had the big brake light but I added the tri bar fascia about 6 mon ths after I bought the bike. I've since changed to CVO fascia and eliminated the big brake light. This is still my stock fender with that big gaping hole but the Yaffe stealth 3 plate bracket bolts directly to the existing holes for that big brake light. As far as the harness is concerned, it may have the same plug but you'll more than likely have to re-pin it to make the bullet brake/run/turn lights work. I had to re-pin my connector to get the CVO lights to work
Big Spoon likes this.
Changing to Streetglide Rear Fender on my 2012 swampking Lighting 4 08-21-2017 04:23 AM
Front & Rear Streetglide Wheels $140.00 flx50 Parts for Sale 6 10-15-2013 01:39 PM
Help!! Helping a brother-Streetglide no run after bar change kiohio Troubleshooting for Road Glides 7 06-23-2013 06:00 PM
3RD Brake Light/TourPak Rack & StreetGlide Rear Facia w/tail/stop light paco ritter Aftermarket Accessories 6 04-20-2011 10:00 PM
2010 streetglide rear wheel and tire and 2006 front wheel for sale bigpete1 Classifieds Archive (3 months old+) 0 12-21-2010 06:47 PM
