Clutch Play in Cable - Road Glide Forums
post #1 of 4 (permalink) Old 12-04-2016, 01:23 PM Thread Starter
I have a 2007 Road Glide in which I began to adjust the clutch cable (after 6000 miles noticed a little extra play) loosened cable adjustment, removed derby cover, backed out screw, tightened until just bottomed and then backed out 3/4 turn....seems normal and a he_ _ of a lot easier than my shovel. I then went to adjust the cable and wooha! It adjust almost all the way out and still more than an 1/8 play at lever.
**My issue....I have heard someone mention that the clog inside the "Clutch Release Cover" can become inverted but not clear if the end issue would be the same as mine.
Thinking the clutch disks may have been to worn, I replaced the clutch assembly with a Barnett Scorpion Assembly, nope...not the disks, still way to much play in cable.
**Does this sound consistent?
Thanks, Enjoy the Holidays!
Harry
71Surfbs is offline
post #2 of 4 (permalink) Old 12-04-2016, 01:29 PM Thread Starter
The Scorpion Clutch looks sweet though...
71Surfbs is offline
post #3 of 4 (permalink) Old 12-04-2016, 02:21 PM
lil chief's Avatar
Maybe try and back the adjuster a 1/2 turn out then adjust the cable. See if that helps out some. On my old FLHT, I had an extended cable due to the reduced reach bars, and the proper adjustment on that one left the cable right at the very end of the threads.
Lil Chief
lil chief is offline
post #4 of 4 (permalink) Old 12-04-2016, 02:55 PM Thread Starter
Thanks, this has ape hangers, the length of cable has been fine for the three years I`ve owned the bike. The extended length only became an issue with this adjustment. I installed and Energy One set of disks and diaphragm spring with great results, I could get neutral at a stop with bike running. All other adjustments (3) no issues, that`s why I puzzled.
Thanks Again,
Harry
71Surfbs is offline
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
Clutch Cable Play 71Surfbs Do-IT-Yourself 2 10-22-2016 07:29 PM
Need Help-Clutch Cable Lever Change-Tight Cable SNemet Controls & Handlebars 6 04-28-2016 05:42 PM
Braided Clutch Cable Repair? hdmagic Troubleshooting for Road Glides 1 08-15-2010 06:30 AM
Clutch cable clip on side of gauge housing GizmoGlide *General Road Glide Discussions/Pictures 8 03-26-2010 12:00 PM
