Dash insert removal? - Road Glide Forums
 12Likes
post #1 of 16 (permalink) Old 01-08-2017, 01:08 AM Thread Starter
Headrope's Avatar
Is a heat gun safe to use to remove dash inserts or is there a better way?
Never been happy with the aluminum dash insert, but it's just a pretty piece so I haven't worried about it. But today I ran across a black one on clearance so figured why not.
2010 Road Glide Custom, 103 big bore, other goodies.
Headrope is offline
post #2 of 16 (permalink) Old 01-08-2017, 01:27 AM
Mike U's Avatar
I used a heat gun to remove mine.
Use the low setting and move it around the emblem and if will start to lift.
It's held on with glue.
Hope this helps.
Mike U.
Headrope likes this.
Mike U is online now
post #3 of 16 (permalink) Old 01-08-2017, 03:44 AM
UT_Larry's Avatar
I suggest a hair dryer. Not as hot.
UT_Larry is offline
post #4 of 16 (permalink) Old 01-08-2017, 02:01 PM Thread Starter
Headrope's Avatar
Cool.
Thanks.
Headrope is offline
post #5 of 16 (permalink) Old 01-08-2017, 02:37 PM
Get it warm and slide a butter knife underneath. Let goo be gone sit on the residual glue over night and take a rag and wipe it clean.
13FLTRX and VikingRider like this.
post #6 of 16 (permalink) Old 01-08-2017, 11:12 PM Thread Starter
Headrope's Avatar
Have had a bad experience in the past with Goo B Gone but y'all know more than me. Thanks for the reply.
Headrope is offline
post #7 of 16 (permalink) Old 01-08-2017, 11:15 PM
Mike U's Avatar
I've used a little bit of lighter fluid, on a rag, in the past to remove glue.
Just rub the glue and it comes off.
Worked well for me.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
post #8 of 16 (permalink) Old 01-09-2017, 07:21 AM
Spazz's Avatar
I did mine in the summer.. peeled and edge and used a brass putty knife
GOO GONE took the glue off pretty easy
IF you are trying to safe it... forget about it.... they are only like $20 to replace and SEVERAL aftermarkets are out there.. I have a custom one.
RENO BAGGER AUDIO
Spazz is offline
post #9 of 16 (permalink) Old 01-09-2017, 07:54 AM
Worked well for me.
Mike U.
I tried that once while drinking and smoking cigars. Didn't work out so well.
post #10 of 16 (permalink) Old 01-09-2017, 09:49 AM
WTFranz's Avatar
Removed several...
Heat Gun or Hair Dryer with dental floss or fishing line to cut the glue under the panel.
Use WD40 to remove glue residue.
mastergunnera8 and Swomack like this.
WTFranz is offline
Dash panel insert removal longrides *General Road Glide Discussions/Pictures 4 02-04-2014 07:59 PM
Dash Insert Skid1 Paint & Bodywork Section 11 01-01-2013 12:54 PM
covintons 08-09 diamond cut black dash insert dirtracer27x Sold 6 05-11-2012 04:23 PM
2011 black powedrcoated dash with insert harley hauler Classifieds Archive (3 months old+) 5 04-05-2012 10:07 AM
blacked out dash with finned billet insert and fuel door. jedi Classifieds Archive (3 months old+) 9 03-17-2012 09:11 PM
