screamin eagle big twin compensater install - Road Glide Forums
post #1 of 8 (permalink) Old 02-28-2013, 03:47 PM Thread Starter
hi, want to install compensater on my 09 rg,do i have to remove inner primary ?
fulkersonic68 is offline
post #2 of 8 (permalink) Old 02-28-2013, 03:51 PM
TRUBlue's Avatar
Welcome from North Carolina. Many questions of this sort are easily answered from the maintenance manual. Most on here will strongly recommend it.
'12 FLTRU Big Blue Pearl
TRUBlue is offline
post #3 of 8 (permalink) Old 02-28-2013, 04:07 PM
06SuperG's Avatar
Welcome from Eastern Iowa.
06SuperG is offline
post #4 of 8 (permalink) Old 02-28-2013, 05:07 PM Thread Starter
thanks trueblue,i have a manual it doesnt say anything about it, but i have read on other sights that you have to grind off a little off housing or loosen the housing up to slide it off.
post #5 of 8 (permalink) Old 03-02-2013, 09:26 AM
I installed the SE compensator on my '08 last summer and used the grinding method. Worked like a charm. The location where the grinding takes place is very thick, and not a lot needs to come off. Before grinding I laid down a coat of shaving cream about 1/2" deep on the primary, under where I was going grind, to trap all the metal I could. Completed the grinding, removed shaving cream with trapped particles, and finished with a thorough flush of the area with WD-40. Did it in about 2 hours.
xshovelfreak is offline
post #6 of 8 (permalink) Old 03-02-2013, 05:04 PM Thread Starter
thanks for the info
post #7 of 8 (permalink) Old 03-30-2013, 05:33 PM
caboverbob's Avatar
Please explain the reason for upgrading/replacing compensator.
Thanks
Peace
CABOVERBOB PILEDRIVERS LOCAL 34 OAKLAND, CA RIDE IT LIKE YA STOLE IT !
'01 FLTRI, T-header, Big Sucker, Terry Comp, S&S 510G, Road 6 Customs, SMW, Arc Audio, JL, Sidecar Cycles, Progressive, Race Tech, Metzeler, JHC
Build thread
caboverbob is offline
post #8 of 8 (permalink) Old 03-30-2013, 05:50 PM
Zog
Zog's Avatar
Thanks
Peace
If you need it you will hear a sickening grinding sound sometimes when trying to start your bike.
2009 Black pearl 110ci,D&D exhaust, titanium gauges, Bright ass lights tailight, madstad windshiled, jac-knife highway pegs, progressive monotones, Ness Deep Cut Hot Legs etc..etc..etc...
Zog is offline
Screamin eagle elite install Canadianharley Intake and Exhaust 5 07-10-2017 09:18 PM
install question screamin eagle pro breather THEMASTERDESTROYER Intake and Exhaust 0 04-21-2015 03:55 PM
Screamin' Eagle® Big Twin Compensator longrides Parts for Sale 3 04-24-2013 11:45 AM
screamin eagle nightstick 2-into-1 slip on muffler plumcrazeman Intake and Exhaust 64 04-18-2011 02:54 AM
Screamin Eagle Heads pte359 Intake and Exhaust 3 01-27-2010 08:15 PM
