Front brake handle hard to pull - Road Glide Forums
post #1 of 3 (permalink) Old 03-19-2017, 09:24 PM Thread Starter
Replaced front brake pads on both calipers and now front brake handle very hard to pull to stop.
Any ideas?
Thanks
firewalker17 is offline
post #2 of 3 (permalink) Old 03-19-2017, 10:04 PM
BlazingSaddle's Avatar
You should be stopping sooner with less travel in the brake lever. In other words, where the brake lever used to pull closer to the grip with the old pads, and perhaps giving your hand more leverage to pull the lever to stop the bike, your lever has less travel, and less leverage is my guess.
The bike should stop as good if not better though. Also, depends on what pads you're now using vs the old pads. Same brand pads? Some pads are "grabbier" than others. Again, new pads will cause the lever to not travel as far as it did when you're brakes were almost shot and probably feels like you have more of a handful.
BlazingSaddle is offline
post #3 of 3 (permalink) Old 03-20-2017, 05:30 AM Thread Starter
That's probably it. I didn't buy the most expensive pads, so these probably don't grab as easy. I was thinking maybe need to bleed them or change the old fluid out. They're saying need to change the fluid every 2 years and its a 6 year old bike. I'll do that anyway but you're probably right about the pads.
Thanks
Handle Bars with more pull back ? mikebrls Controls & Handlebars 14 09-05-2018 06:49 PM
How hard is too hard? tlottman *General Road Glide Discussions/Pictures 11 08-28-2015 06:42 AM
Handle Bar Pull Back ? FLTRXS18 Controls & Handlebars 2 03-26-2015 05:46 AM
Hard clutch pull. StGhost Engine Related 2 12-07-2012 09:02 AM
front brake handle joejoeshovelhead New Members Welcome Area 33 05-02-2012 11:03 PM
