Wireless Phone charging for $25.00 - Road Glide Forums
  • 1 Post By Alcyone92
post #1 of 1 (permalink) Old 03-30-2017, 10:01 PM Thread Starter
Alcyone92's Avatar
What you will need
1 2.1amp or higher USB charger, I used a Motopower MO0609 3.1Amp waterproof
1 3-coil wireless charger that will lay flat, here I used RAVpower RP-WCN15
1 USB A to Micro B cable 6 $0.62 at monoprice.com
3M double sided tape
Small pieces of sheet metal
I took sheet metal and formed a brace to hold my phone. This will be up to you to fit your phone, mine was a Galaxy S7. Secure the sheet metal to the charging plate with 3M double sided tape. One side is full length the other is about 1 inch due to the design on the left storage box. Make any necessary holes or slots for phone buttons.
Drill a hole to the appropriate size to allow you power leads to pass thru. Tap into the cigarette lighter for power. Make the connection as you see fit. I personally removed the entire storage box, soldered all my connection and made it so I could disconnect if needed.
Secure the USB port to the inside of the storage box with 3M tape and connect to the charging plate with 6 USB cable.
Mach1 likes this.
Alcyone92 is offline
2017 FLTRU glove box phone charging. Weak. HellInABucket *General Road Glide Discussions/Pictures 12 07-25-2017 01:38 PM
Phone not Charging - 15 RGS AFD68 Audio 3 06-20-2015 09:52 PM
Phone not charging, 15 RGS rangestrider Troubleshooting for Road Glides 9 11-29-2014 11:49 AM
iPhone 4S - Charging/Not Charging dinggus Audio 8 11-01-2013 08:25 AM
