My Garage Door Opener Mod. - Road Glide Forums
post #1 of 8 (permalink) Old 03-25-2013, 10:42 PM Thread Starter
Stickman81's Avatar
Today I replaced the stock RGU handlebars with the Heritage style bars.
https://www.roadglide.org/showthread....d=1#post423089
Since I had the instrument bezel off, I opted to install my new Iron Aces Standard Mount and, my garage door opener.
I saw this method of installation in another thread on here so I cannot take any artistic credit. I have not found the original thread to link to but I will look for it in an attempt to give credit where it is due.
I already had the opener modified for use on my Street Glide that I just traded-in for the 2011 RGU. The opener was opened and a Harley Davidson Odometer switch (momentary style switch) was used.
The opener circuit board remained inside its stock housing.
The entire unit fit just fine into the instrument bezel housing when it was reassembled.
Here are a couple of pictures.
Instrument bezel out and garage door opener awaiting installation.
I have just installed the Iron Aces Standard Mount.
Hole was laid-out on the back-side of the instrument bezel.
I was surprised as easy as it was.
View of the odometer switch installed.
Installed back on the bike.
Jim
"Ride safe, have fun, wash hands often".
Current: '11 Road Glide Ultra. (3-9-13)
Stickman81 is offline
post #2 of 8 (permalink) Old 03-25-2013, 10:51 PM
cnidog's Avatar
Nice job. This is something else to add to the mod list. Thanks for sharing.
"where the incompetent lead the inexperienced, to do the unnecessary, just in case" - me
IBA Member # 55664
cnidog is offline
post #3 of 8 (permalink) Old 03-26-2013, 06:52 AM
Wild Bill Coady's Avatar
I like the clean finish . . . what size drill bit was used?
RUBBER SIDE DOWN . . . the other way just hurts!
2011 Road Glide Ultra
2003 Electra Glide Classic (RIP 9/3/11)
1987 XLH 1100 30th Anniversary
Wild Bill Coady is offline
post #4 of 8 (permalink) Old 03-26-2013, 09:06 AM Thread Starter
Stickman81's Avatar
Thank you.
I used a 25/64" drill bit.
It is an okay fit, not great.
The switch has flat edges on two sides at the ends of the threads, near the housing of the switch. These are to prevent rotation when properly installed. I did not have anything to make a square hole, or, at least flatten out two sides of the circle. The location of the switch has the housing sandwiched between the gauges. Once the rubber cover is screwed on, the switch housing will not rotate.
Jim
post #5 of 8 (permalink) Old 03-26-2013, 09:09 AM
HellInABucket's Avatar
I think I used a 3/8 for that when I drilled my console on my road King for the HD momentary switch.
2020 FLTRK
Roll away the dew...
HellInABucket is offline
post #6 of 8 (permalink) Old 03-26-2013, 09:13 AM
jim_b's Avatar
Re: My Garage Door Opener Mod.
I did this about a year ago. Every time my bike goes in for service they try to use this to check my odometer setting. This really should have been where the odometer switch went!
2010 FLTRX Vivid Black With Supertrapp Fatshotz, V & H Dresser Duals, PCV, Big Sucker, SE 255 Cams, 12" Wild 1 Outlawz, MadStad 16", HogTunes Amp/5x7 Fairing Speakers, Mustang Wide Tripper W/Pillion, List Goes On And On
jim_b is offline
post #7 of 8 (permalink) Old 03-26-2013, 07:29 PM Thread Starter
Stickman81's Avatar
Ha. +1.
I did not think about that.
Jim
post #8 of 8 (permalink) Old 03-26-2013, 08:40 PM
zemo1017's Avatar
To drill a "square" hole you need to drill two holes with a bit that matches the width of the flat to flat measurement for the top and bottom of the opening. Use a Dremel or other rotary tool to cut the flats. A flat file will work if a Dremel isn't an option.
Or lay it out and use a Dremel to cut the shape.
zemo1017 is offline
My DIY garage door opener DSTdrummer Do-IT-Yourself 91 06-27-2019 06:36 PM
My free garage door opener mod Timinfla2 Do-IT-Yourself 18 08-28-2015 12:55 PM
Garage Door Opener for $11.62 dklanecky Do-IT-Yourself 108 04-29-2015 03:55 PM
Very slick garage door opener, mo-door roadie13 Aftermarket Accessories 1 03-31-2015 07:50 PM
Garage Door Opener and More EZMotoTim Do-IT-Yourself 7 08-21-2010 07:31 PM
