NEED Timken part ##'s or Options 2010 ABS - Road Glide Forums
post #1 of 3 (permalink) Old 03-26-2013, 11:57 AM Thread Starter
h-donut's Avatar
does anyone have a list timken bearings for our bikes, I have the 2010 ABS
I have been attempting to re-tool and get back to doing my own, nothing bad against the system, just finding it less work in the end
then you have the tools and knowledge for next time
on the very strong side of replacing OE bearings with better timken bearings
front bearings barely turned after 25k mi, looser on the right hand side, lubed them up and let them sit, seemed acceptable so I put them back on the bike.
rear bearing aren't finger turning at all.
a. first, is this normal? I have heard that the rears won't finger turn
b. front, I've also heard those have different resistance, for ABS reasons
in this situation, I'm thinking replacing them all with some old school timken brand bearings would be the advantageous thing to do.
so does anyone have any leads on a good shop or tech that could order the parts, or p/n's including what type of puller works best?
or expert advice or what to do, check for and some big brain common sense?
thanks in advance
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #2 of 3 (permalink) Old 03-26-2013, 01:03 PM
FLTR2008Trike's Avatar
thanks in advance
HD went from the 3/4" axle with the tapered roller bearing we could repack with grease. To a 1" axle with the sealed bearings, to the 25mm axles currently being used now with the INA bearings.
Because you have the ABS system there is no direct replacement for the sensor INA encoder bearing for the ABS. The best option is to change these bearings front and rear when you put on new tires. This wont guarantee that a bearing wont fail between tire changes but will lower the chance of it.
If you want to get the tool to remove the bearings and install them Georges Garage has a kit #740010 >>
http://www.georges-garage.com/chassis_tools.htm
The other 2 tools you will need for the rear tire removal is # 740050 & 740060
Tom
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
post #3 of 3 (permalink) Old 03-26-2013, 01:56 PM Thread Starter
h-donut's Avatar
wasn't really planning on spending $700 in tools
wouldn't a slide hammer with attachments work okay?
re: the bearings, I guess I could remove the dust caps and inspect, see if there's anything left
I appreciate the effort of dealers 110% at this point, knowing they are more than likely swapping these out all day, everyday
h-donut is offline
Bonding ABS to ABS or fiberglass? Monkeyman Paint & Bodywork Section 8 04-28-2012 02:16 PM
Timken style floating bearings and spacers roadglidecali Do-IT-Yourself 0 11-12-2011 12:08 PM
Timken part # needed. Cotton Hill *General Road Glide Discussions/Pictures 3 11-10-2011 08:16 AM
Timken convertion whats it good for??? gabbyduffy Engine Related 8 05-07-2011 09:36 PM
Axel Bearing Cross ref # to Timken? spraypilot *General Road Glide Discussions/Pictures 2 02-18-2011 07:55 AM
