My DIY garage door opener - Road Glide Forums
 60Likes
post #1 of 85 (permalink) Old 05-22-2017, 06:31 PM Thread Starter
DSTdrummer's Avatar
Send a message via AIM to DSTdrummer Send a message via MSN to DSTdrummer
I just thought I would do a little write-up on how I did my garage door opener.
I wanted the remote up front, as it was a little finicky under the side panel on my Ultra.
I didn't get pics of it, but I just soldered the wires to remote board where the rubber button contacts to activate.
It didn't seem like I had many options on the RG without pulling the outer fairing and digging in to the birds nest in there. But I was able to put high enough, and in a decent spot for me to get at it, as well as finding it in the dark. I thought about a button with the lighted ring, but I didn't want to deal with wiring to a keyed source, (and I didn't think the light color would match the gauge lights).
I used a waterproof, "boat horn", momentary button I found on eBay. It has a rubber O ring to keep water out.
I was able put it right under the top vent panel.
The wire tie did not hinder getting the clip back in the slot either.
Although....I used a step bit which was too long and hit that little plastic mount there right behind the button.
A regular 5/8 bit would have been better to finish with, but 1/2 was all I had. So it got a little wonky.
Here is the button from riders side.
All-in-all, a very simple job that only cost $4, as I already had the opener and scrap wire from work.
08Zinc, Bruce00, madmat and 5 others like this.
FORMER-2006 FLHTCUI~Black Pearl (Grey)~Screamin' Eagle 103~K&N~Rinehart True Duals~Power Commander
CURRENT-2017 FLTRU~Vivid Black~No Mods Yet
DSTdrummer is offline
post #2 of 85 (permalink) Old 05-22-2017, 07:20 PM
Good job, that looks clean! Now for all the people to tell you that they just keep their opener in the glove box or in their pocket.. :-)
2015 FLTRXS - Spookyfast bars D&D Fatcat
2009 Vivid Black FXDB PC-V D&D Fatcat
az777 is offline
post #3 of 85 (permalink) Old 05-22-2017, 07:30 PM Thread Starter
DSTdrummer's Avatar
Thanks!!
Also, I did keep it it the glove box for about a week. Had it clipped in the edge of the rubber dealio in there. But it didn't want to work all the time, and I hated having to pull it out to open the door. Mainly cuz my driveway is up hill. If I end up in the driveway and it's not up, I was having to hold the brake, fiddle with the remote. Psh....
I like to open it as I'm coming down the road, and ride right on in there.
Plus, I miiiiiight have a slight lazy streak in me.
Only slightly, only slightly. Heh heh.
post #4 of 85 (permalink) Old 05-22-2017, 08:15 PM
Nice job! How is it that your inner fering is matte black?
dozer23 is offline
post #5 of 85 (permalink) Old 05-22-2017, 08:21 PM Thread Starter
DSTdrummer's Avatar
Mine isn't a CVO. I have the FLTRU.
post #6 of 85 (permalink) Old 05-22-2017, 08:53 PM
dinger5's Avatar
nice clean job!! I was thinking about doing the same thing, now i gotta do it!! good to see pics!!
DSTdrummer likes this.
dinger5 is offline
post #7 of 85 (permalink) Old 05-22-2017, 09:10 PM Thread Starter
DSTdrummer's Avatar
Thanks!
The hardest part was:
A) Deciding where to put it
2) Actually drilling a hole in the dash of my brand new bike.
MadCow likes this.
post #8 of 85 (permalink) Old 05-23-2017, 11:10 AM
Stick_FSMC's Avatar
Looks fantastic! Nice clean install.
I used to keep the remote in the left glove box. I hated trying to reach in there and do a slow speed left turn into the driveway at the same time, so I wanted an easy to use installation like yours.
I chose to do it a little differently on my 2012. I put the remote inside the Gauge Nacelle, and installed the button there. I used the same type of switch that is used for the trip meter reset so it would look as close to a factory install as possible.
Looks like you don't have as much room in that area. I powered it from the Aux Power connector under the seat. That's the same power source I used for the driving lights I installed.
vring, Bigfoot and DSTdrummer like this.
Stick
USAF 1980-84
Stick_FSMC is offline
post #9 of 85 (permalink) Old 05-23-2017, 11:29 AM
WTFranz's Avatar
That's awesome!
Thinking If i used one of the Aux Buttons below the Speedo cluster then everything is stock looking.
Question to HD MoCO, Why is their Garage opener $450 and not $4 or even $44
Mazikeen - 2016 Road Glide Special from Arizona
WTFranz is offline
post #10 of 85 (permalink) Old 05-23-2017, 12:13 PM
Originally Posted by WTFranz View Post
That's awesome!
"Why?" Because they can. Enough people are paying that price. They would lower it or discontinue otherwise.
DSTdrummer and Obxrggpd like this.
Buzzy is online now
My free garage door opener mod Timinfla2 Do-IT-Yourself 18 08-28-2015 12:55 PM
Garage Door Opener for $11.62 dklanecky Do-IT-Yourself 108 04-29-2015 03:55 PM
Very slick garage door opener, mo-door roadie13 Aftermarket Accessories 1 03-31-2015 07:50 PM
MY DIY garage opener mark_bert Do-IT-Yourself 12 05-29-2013 10:56 AM
My Garage Door Opener Mod. Stickman81 Do-IT-Yourself 7 03-26-2013 08:40 PM
