Tpms - Road Glide Forums
post #1 of 17 (permalink) Old 05-30-2017, 10:22 AM Thread Starter
ia15rgs's Avatar
Tpms
so im gonna guess finding a CVO head unit and the valve stems are not the only way to put TPMS on my bike...ive seen a few that even run with Garmin. i use the onboard or my iPhone. can someone recommend a TPMS or what are you using?? i know i know...cuz its so hard to check my tires
ia15rgs is offline
post #2 of 17 (permalink) Old 05-30-2017, 11:02 AM
UT_Larry's Avatar
FoboBike. Make sure you also get the metal valve stems.
UT_Larry is offline
post #3 of 17 (permalink) Old 05-31-2017, 01:37 PM
tpms
I have the fobo bike tpms and like it. I too recommend the steel valve stems. I got the "T" valve from them for easy of use.
FLTRXS18 is offline
post #4 of 17 (permalink) Old 05-31-2017, 01:39 PM
sfcusaret2004's Avatar
How do the tpms work with green slime or ride-on tire sealant?
sfcusaret2004 is offline
post #5 of 17 (permalink) Old 05-31-2017, 08:36 PM
Fobobike, works like a charm and easy to use.. Recommend that you buy the T metal valve stems..
Contact info:
Bob Mutch at Fobobikesales is a good guy to deal with..
FOBO Bike Sales | Your Motorcycle TPMS System Supplier - FOBO Bike Sales
mpears53 is offline
post #6 of 17 (permalink) Old 05-31-2017, 10:32 PM
Bbally's Avatar
Tpms
DO NOT use FOBO with rubber valve stems. The instructions on measuring rubber stem deflection and any person that tells you anything else is a lying. Period.
You will need a tire are steel valve stems.
But other than that I agree it works great!
USMC 79-85
Bbally is offline
post #7 of 17 (permalink) Old 06-01-2017, 07:45 AM
Well Just checked out the FOBO site to see if they would work for me and this was on the home page-
"Please be aware:
FOBO Bike sensors will not fit Harley Davidson motorcycles with side mounted valve stems or dual rotors. They will work on front wheels with single rotor only. Clearance must be checked before riding."
This leaves aout us ultra riders and those of us with side stems! moving on.....
post #8 of 17 (permalink) Old 06-01-2017, 08:13 AM
Bbally's Avatar
I have dual rotors. No problems.
Side stems i get ... the weight spinning will pull them out or break them off
Sent from my SAMSUNG-SM-G891A using Tapatalk
USMC 79-85
Bbally is offline
post #9 of 17 (permalink) Old 06-01-2017, 01:57 PM
UT_Larry's Avatar
When I got my FoboBike for my '15 RG they did not have an HD or dual rotor warning. Just one that recommended metal stems, but new rubber stems were fine. The rubber stem tore and I slowly lost pressure. Got the FoboBike alarms. Replaced with the metal T valve stems. No clearance or other problems. Different rims could have the valve stem hole located off center which could be a problem. Tape a quarter to the valve stem to get an idea about clearance.
UT_Larry is offline
post #10 of 17 (permalink) Old 06-01-2017, 01:57 PM
UT_Larry's Avatar
UT_Larry is offline
CVO TPMS on a special... RFG7680 Tech Area 37 04-16-2019 01:32 PM
Malcam TPMS Morningwood Aftermarket Accessories 18 03-17-2018 07:03 PM
FOBO TPMS T-valve Pictures tsmartt Wheels and Tires 19 01-17-2018 06:29 AM
