Preforming 1k service! - Road Glide Forums
 2Likes
  • 1 Post By Desertwndrr
  • 1 Post By RFG7680
post #1 of 6 (permalink) Old 06-01-2017, 12:13 AM Thread Starter
Cbordies's Avatar
Hello all,
I'm gathering all the necessary fluids and parts to do my 1K service on my 2017 RGS. Redline makes a kit that comes with the necessary fluids such as 20W-50 oil, primary fluid, and transmission fluid. I found replacment gaskets for the drain plugs but I cant seem to find the gaskets for the derby cover for the 17' to replace it when I do the service. I would really like to avoid going to the stealer due to the high price they charge for the service plus labor. Anyone know where I can get the gaskets from? Are they the same as the 16' model? I know its a different motor but did they atleast keep the gaskets the same? Any and all help is appreciated. Also any advice on things to check other than what the manual says!
Cbordies
Cbordies is offline
post #2 of 6 (permalink) Old 06-01-2017, 12:21 AM
Desertwndrr's Avatar
The derby cover has a thick orange rubber gasket that is reusable. If you changed the derby cover then you will have to have a different gasket.
Cbordies likes this.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #3 of 6 (permalink) Old 06-01-2017, 12:26 AM Thread Starter
Cbordies's Avatar
Pretty much everything on the bike is stock like it came from the factory. Just want to make sure I do it right. I'm not one to cut corners on my bikes. Thank you for the heads up on the gasket though, I really appreciate it!
Cbordies is offline
post #4 of 6 (permalink) Old 06-01-2017, 03:31 AM
RFG7680's Avatar
Make sure you get a copy of the check list. There is more to it than just the oils. Critical fasteners and a few other things get looked at. And re-torqued.
RFG7680 is online now
post #5 of 6 (permalink) Old 06-01-2017, 04:24 AM Thread Starter
Cbordies's Avatar
Will do! The dealer can furnish that can't they? I know there is a list in the owner's manual of what needs to be done at the 1k but I would expect theirs to go into a bit more detail?
Cbordies is offline
post #6 of 6 (permalink) Old 06-01-2017, 04:33 AM
RFG7680's Avatar
I doubt they will. There's one here I think. If not I am pretty sure HDForums has it. There's a thread there with all the service intervals and what is done.
1K Service Candy_R3dd Do-IT-Yourself 8 08-26-2013 08:14 PM
1k service question MoparMarv *General Road Glide Discussions/Pictures 10 08-10-2013 05:42 PM
How long for 1k service mmfinn *General Road Glide Discussions/Pictures 17 07-07-2013 11:27 PM
1k Service HDGLIDE Do-IT-Yourself 9 04-08-2011 08:13 PM
1k Service Situation OldSalt Road Glide Specific Discussions 8 01-18-2011 06:13 AM
