Insulation - Road Glide Forums
post #1 of 13 (permalink) Old 06-04-2017, 08:25 PM Thread Starter
Insulation
Has anyone found a simple stick on insulation that can be used for both saddlebags and tourpack? I am not looking for enough to keep things cold, but just enough to keep the heat down. It gets to well above 100 here.
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #2 of 13 (permalink) Old 06-14-2017, 01:47 PM
ChromeSpark's Avatar
Possibly the stuff used under car carpet? Keeps heat from engine bay off the feet.
"It's a motorcycle, itīs not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s**t your pants every now and then."
ChromeSpark is offline
post #3 of 13 (permalink) Old 06-16-2017, 01:42 PM Thread Starter
hmmmm
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #4 of 13 (permalink) Old 06-16-2017, 02:08 PM
Do you care what it looks like? If not, I would suggest getting a roll of Reflectix at Home Depot/Lowes. It is cheap (less than $20 for a big roll), fairly thin and very effective. I've used it on various pieces of brewing equipment with great success. You will need some double-sided tape or velcro tabs to keep it in place, and it will be a little time consuming trying to make a good template for all the inside surfaces, but I believe it would be well worth it in the end.
Or perhaps just get a couple of soft-sided coolers to keep things in and call it good. Sometimes simple is good enough.
macabra11 is online now
post #5 of 13 (permalink) Old 06-16-2017, 02:39 PM
UT_Larry's Avatar
I got the HD liners, they are made out of a felt like material and do seem to provide some insulation. You would still need to add insulation to the lids. Not sure if they would provide as much insulation as what you're looking for, and they are expensive. Got mine for free using reward points. The do provide good protection for the saddle bags and contents.
https://mstore.harley-davidson.com/s...addlebag-liner
UT_Larry is offline
post #6 of 13 (permalink) Old 06-16-2017, 04:54 PM
You can also get a roll of Dyno-mat at your local auto parts store. Usually found near the stereo equipment.
post #7 of 13 (permalink) Old 06-16-2017, 06:12 PM
What about this for your saddle bags?
https://www.harley-davidson.com/store/saddlebag-cooler
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #8 of 13 (permalink) Old 06-16-2017, 06:16 PM
I wonder how rugged that bag is ? That would also dub as a great travel bag .
post #9 of 13 (permalink) Old 06-16-2017, 07:30 PM
My buddy has a pair. When we go on road trips, one carries cold stuff & the other clothes. He hasn't had any problems so far. I forgot to mention he does use a heavy garbage bag to line his liner. He's OCD just like me.
post #10 of 13 (permalink) Old 06-22-2017, 06:44 PM Thread Starter
Lots of great ideas. I will have to check some out. I was not looking to keep things cool, like water or soda, or..... I just wanted to keep out or reflect some the heat generated inside my bags and tourpack.
2018 Road Glide
ABS. Boom Audio
pauld is offline
Insulation behind speakers? Kudu40 Audio 17 08-29-2013 01:09 PM
