Started "winter" mods, finally - Road Glide Forums
post #1 of 9 (permalink) Old 04-04-2013, 06:54 PM Thread Starter
Howardsternspenis's Avatar
Cool Started "winter" mods, finally
So they're not so much winter mods as they are spring mods.
I don't have a garage and the weather hasn't been very cooperative here in the mid-Atlantic so cut me some slack.
Anyway, finally had a decent afternoon so I dug in.
I've got Hog Tunes, 5X7's to go in, new oil temp gauge, red, Super Bright LED's, for all the fairing gauges, Heat Demon's grip warmers, new grips and a new horn cover.
First, I took off the left saddlebag to get to the side cover to remove the main fuse. Safety first!
Then, I removed the windshield. I had replaced the stock wind screen last year and maybe I over tightened the well nuts cause a couple of them were a bitch to get out.
Next off came the outer fairing. Pretty easy, remove the turn signals, remove the six screws holding the fairing halves together, two "long" screws on the bottom and four short screws in the middle and on the top, pop it up, unplug the headlights and done.
I knew I wouldn't finish everything today and I don't have a safe place to store the outer fairing so I planned on hanging it back on between sessions so I removed the headlight bezel and the headlights.
Removing the stock bezel was a bitch but getting the headlight assembly out was EZ. Squeeze the three green tabs and it pops right out.
First thing was gettin rid of the stock fairing speakers.
Before I started taking the old speakers out I wanted to make sure the Hog Wired grills i bought would fit and yea, they would, if Hog Tunes hadn't glued their grills on! Grrrrrrr! Wasted $$$$$
On that note, it appears that the stock speakers AND Hog Tunes have the same as Hog Wired grills just with a cloth covering. I'm assuming to try and keep out the H2O.
So, removed the speednut, remove the three screws holding the grill onto the inner fairing. Hog Tunes is VERY specific in their rather brief installation instructions that the factory grill screws are NOT to be reused with the HT speakers. The stock screws are longer than is needed for the HT grills and would DEFINETLY poke through the inner fairing if reused. BE AWARE!
Next I removed the worthless air temp gauge and got a feel for exactly how to remove the stock light bulb. Just grab the back of the lamp holder with a pair of pliers, wiggle and pull.
Then I put in the new oil temp gauge, with it's new, red LED, in the inner fairing. I hooked the power for the light up so I could make sure I did it right. I put the main fuse back in and yep, I can screw in a lightbulb! I'm saving the remainder of the oil temp gauge install for tomorrow or Saturday.
Oh, at this point I also checked the new speakers. SWEET! Much better sound!
Then I took the main fuse back out and put the new red, LED's in the remainder of the gauges in the fairing. Main fuse back in, checked all the gauges and all the new LED's are working.
This was the point at which I knew it was time to call it a day.
Tools away, outer fairing back on, left the turn signals hanging, wrapped in a shop cloth so as not to scratch them or anything else, main fuse back in, side cover back on, left saddlebag back on, windshield, headlight bezel and headlight assembly safely tucked away, cover back on and it's Miller Time.
So with this all said, I still need to do the wiring for the oil temp gauge, I haven't even looked at the instructions yet to see how I'm supposed to run the cable and install the sensor. I also haven't taken the speedo/tach nacelle off to get an idea of what else I need to take off to do the wiring for the Heat Demon's.
So I'll post my findings, trials and tribulations as I proceed.
I really hope I can have all this done by Sunday so I can go for a ride. Supposed to be in the upper 60's and sunny but we'll see.
Bye for now!
HSP
Howardsternspenis is offline
post #2 of 9 (permalink) Old 04-04-2013, 07:02 PM
Peewee's Avatar
Sounds like your doing great! The mod lists sound good! Keep up the good work!
"Know Thyself"
Peewee is offline
post #3 of 9 (permalink) Old 04-05-2013, 05:50 AM
btfochad's Avatar
Great minds must think alike - I did three of the same things to my scooter over the winter...hogtunes 5x7, red LEDs, and oil temp gauge!
2010 Road Glide
14" Apes
Knight Prowler TW-555 Cam
btfochad is offline
post #4 of 9 (permalink) Old 04-05-2013, 06:26 AM
Jetman's Avatar
Man I feel bad that your doing all that outside. Next time your needing to work and need a dry place, let me know.......I'm less than 3 hours and have plenty of space...........
2012 - Big Blue Pearl
Heavily Accessorized.....
Jetman is offline
post #5 of 9 (permalink) Old 04-05-2013, 06:50 AM
RhinoHD's Avatar
Sound like you got it under control. Feels good to get mods done don't it.
Life is good but it's not easy!
RhinoHD is offline
post #6 of 9 (permalink) Old 04-05-2013, 06:56 AM
Wild Bill Coady's Avatar
Best of luck with the final steps. I did the Hog Tunes Big Ultra and wedge bulbs this winter myself. Of course went blue and had to send the tach, speedo and radio out. All in all, it's time for the riding season to start here in Maryland. Hope to hear you on the roads??
RUBBER SIDE DOWN . . . the other way just hurts!
2011 Road Glide Ultra
2003 Electra Glide Classic (RIP 9/3/11)
1987 XLH 1100 30th Anniversary
Wild Bill Coady is offline
post #7 of 9 (permalink) Old 04-05-2013, 07:47 AM
CNMTurner's Avatar
Yo Bro.. I'm only a couple of miles from ya.. Need garage space to work on your bike.. Give me a call anytime.. or drop me a PM..
2010 FLTRX - Stage 4 SE 113 - MVA Heads, 10.5:1, SE266E cams, 58mm TB, 5.3 gr/s injectors, Polished and plated motor and trans and a few chrome extras. Fullsac DX Header and Freedom Performance Classic 4" Slip-ons. Titan II 6.5 speakers with RF PBR300x2, Monroe Airshocks
1996 Tail dragin' Fatboy
CNMTurner is offline
post #8 of 9 (permalink) Old 04-05-2013, 09:03 AM
DED HD's Avatar
Be sure and take your time, don't want to screw anything up trying to get all your "winter" mods done now that spring is here.
'10 Red Custom:
DED HD is offline
post #9 of 9 (permalink) Old 04-05-2013, 03:35 PM Thread Starter
Cool Thanks!
Ya'll may regret making me that offer some day!
I promise I'll bring beer though.
HSP
SWII inspired winter mods have started... cnidog General Off-Topic Discussions 11 02-02-2013 10:15 PM
Winter Mods finally done... Jebster *General Road Glide Discussions/Pictures 22 03-31-2012 09:02 PM
Winter mods gettin started thanks to drago Rowdy Audio 4 01-02-2012 03:26 PM
Winter mods are finally done! cleanrider *General Road Glide Discussions/Pictures 20 05-03-2011 04:58 PM
Winter Mods Started fxstdi *General Road Glide Discussions/Pictures 11 11-11-2010 01:25 PM
