09 Glide fires, then idle increases and dies - Road Glide Forums
 4Likes
post #1 of 15 (permalink) Old 06-28-2017, 08:57 PM Thread Starter
Strix's Avatar
Exclamation 09 Glide fires, then idle increases and dies
Hey Guy,
Been a while since I have been here. I need some help please. My bike died on me going home last Wednesday. I could get it to start but it would sputter, backfire and stall after running the idle over 2k.
I checked the codes and got an o2 sensor code, so I started with the least expensive part of the system fuel filter needed replacing and checked the pump.I have replaced the Ignition coil (ohm'd out low), both o2 sensors. I have checked all of the connectors that come from the wiring channel under the tank to the injectors, I have checked for intake leaks. Hell I even broke open the timing case to see if I lost a chain tensioner. I have disconnected the power commander and plugged directly into the ECU and the result is the same. What am I missing?
Any ideas?
2009 RG, stage 1, Freedom Pipes, Burley apes and assorted other accessories.
Ride until you can ride no more
Strix is offline
post #2 of 15 (permalink) Old 06-29-2017, 06:32 AM
MightyWhitey's Avatar
So tough to help diagnose from so far away. I'd still say fuel. Sounds like a lean condition to me. You could also have lost your TBW connection. Do you have aftermarket bars? Did you replace that green plug with an SE TBW sensor? Just spitballing here.
MightyWhitey is offline
post #3 of 15 (permalink) Old 06-29-2017, 09:38 AM Thread Starter
Strix's Avatar
I do have aftermarket bars, I added 14" Z-bar apes about a year ago. I unpinned the stock plug and ran the wiring internal and re-pinned it. I was thinking last night that maybe one of the throttle wires had possibly chafed through and was grounding inside the bars. Something else for me to check I suppose. Honestly all that I have left to consider in the systems are the Crank position sensor and possibly a hole worn through the feed tube in the tank coming from the pump. And of course the ECM itself.
Thanks for the response it kind of confirms my thinking.
Strix is offline
post #4 of 15 (permalink) Old 06-29-2017, 10:01 AM Thread Starter
Strix's Avatar
Actually, the more I think about it, after changing the o2 sensors last night and firing it up, it started immediately which it hadn't been doing, went right to 1000rpm for about 30 seconds and then ran up to about 2K then dropped down to around 600 sputtered and backfired. Did that for about two minutes. After I shut her down I checked for codes and had none. That really makes me thing fuel more that Crank position sensor.
Strix is offline
post #5 of 15 (permalink) Old 06-29-2017, 11:43 AM
Dragon Dude's Avatar
Could be a dirty IAC, you might could clean it or replace it. Bad TPS? Just some suggestions.
Dragon Dude is offline
post #6 of 15 (permalink) Old 06-29-2017, 11:47 AM
Thermodyne's Avatar
OK step back and start over. What was the code(s)? Some 02 codes relate to the sensor itself and some relate to what it is seeing. Each code has a specific diagnostic ladder that greatly reduces the replacement of parts based on hope. "I hope this fixes it" can be a very expensive repair strategy.
On a 09 with a idle speed issue, the first thing to do would be to clean the terminals in the throttle body connector.
Record the codes and then clear them. Clean the connector pins. You almost have to release them from the connector to get them clean. Then reinstall and see how it runs and if it codes again. If it runs poorly or codes, diagnose it accordingly. If it fixes it, go on down to the MoCo with some money and a band-aid and buy a set of new terminals. If you don't have the tool to crimp them on with, it's cheaper to pay them to do it as opposed to buying the tool.
Next thing to buy would be the Electrical diagnostic manual, 99497-09. Best $50 you'll ever spend on that scooter.
RGKen likes this.
Thermodyne is online now
post #7 of 15 (permalink) Old 06-29-2017, 06:44 PM Thread Starter
Strix's Avatar
Great input, Thank you
Strix is offline
post #8 of 15 (permalink) Old 06-29-2017, 06:46 PM Thread Starter
Strix's Avatar
I already checked and cleaned the TPS, had not thought about the IAC. Thanks
Strix is offline
post #9 of 15 (permalink) Old 06-29-2017, 06:58 PM
RGKen's Avatar
Your 2009 RG doesn't have an IAC. All bikes with TBW do not have it. Only bikes with cable throttle.
2018 FLTRXS
RGKen is online now
post #10 of 15 (permalink) Old 07-02-2017, 12:27 PM
snarley53's Avatar
make sure you haven't lost your bell, gremlins are hell to get rid of without a bell.
2011 roadglide ultra.2000 93" s&s rigid panhead,
40 ford rat rod pickup
snarley53 is offline
low idle and lopes and dies billbeemer *General Road Glide Discussions/Pictures 13 02-15-2018 10:54 PM
2015 RGS Erratic Idle and Dies at Acceleration tlottman Troubleshooting for Road Glides 41 09-14-2017 06:51 PM
Engine chirping/rattle then BANG - then nothing Methos1979 Troubleshooting for Road Glides 16 07-02-2016 09:11 AM
bike dies at idle drmudd Troubleshooting for Road Glides 1 05-13-2012 09:48 PM
01 Road Glide - Dies NO power then starts OnPhyre Troubleshooting for Road Glides 8 03-09-2012 09:45 PM
