Fuel line Quick Disconnect - Road Glide Forums
post #1 of 10 (permalink) Old 04-07-2013, 09:54 AM Thread Starter
I have a 07 RG. Spent the weekend doing the homemade air ride and new Hog Tunes amp and speakers. Tried to remove the fuel tank to run my wires but I could not get to the fuel line quick connect on the tank for a chrome trim piece that has been installed. It appears to have three small screws on the back side but I can not get to the screws to remove them to get to the quick connect fitting. Anyone run into this?
Thanks
Jeff
jnd42697 is offline
post #2 of 10 (permalink) Old 04-07-2013, 10:10 AM
RhinoHD's Avatar
Get a buddy to hold the tank up (after unbolting it) so you can access the screws. Just taking a stab at guessing here..
Life is good but it's not easy!
RhinoHD is offline
post #3 of 10 (permalink) Old 04-07-2013, 10:36 AM Thread Starter
Could not get at it to do that. Worried I might break the line really.
jnd42697 is offline
post #4 of 10 (permalink) Old 04-07-2013, 10:38 AM
mocotom's Avatar
I have an allen wrench cut down specifically for that purpose. The shorter allen wrench is the only way I have found to remove that cover, and it will still test your patience. I cringe every time I have to deal with them.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #5 of 10 (permalink) Old 04-07-2013, 01:40 PM Thread Starter
Thanks mocotom, I will cut one don and give it a shot. I may not put it back on.
jnd42697 is offline
post #6 of 10 (permalink) Old 04-07-2013, 01:52 PM
rageglide's Avatar
What quick disconnect are you trying to get to? There are two. Maybe I don't understand what you're doing, but I've had my '12 tank off and it was unbelievably easy compared to any other tank I've dealt with. Same quick disconnect as the older tanks.
edit - I thought '07 had 6 gal tank... So you still have the front cross over. Same tank quick disconnect tho. I used line clamps and cut the crossover when I needed to remove on my '05.
rageglide is offline
post #7 of 10 (permalink) Old 04-07-2013, 03:22 PM Thread Starter
Rage it is the quick disconnect on the left side of tank. It has an aftermarket chrome cover on it that I can not figure out how to get it off to access the quick disconnect.
jnd42697 is offline
post #8 of 10 (permalink) Old 04-07-2013, 03:30 PM
hotrodad's Avatar
jnd
I have a chrome cover (HD) on my fuel line disconnect. It has three small allen screws holding it on. You should be able to feel the holes or use a dental mirror os similar to see where the holes are. I don't recall the allen wrench size 1/16" - 1/8" range maybe.
Good luck
2005 FLTRi
Black Pearl
Live to Ride ~ Ride to Live
hotrodad is offline
post #9 of 10 (permalink) Old 04-07-2013, 09:27 PM Thread Starter
Thanks Hotrodad.
jnd42697 is offline
post #10 of 10 (permalink) Old 04-09-2013, 04:53 PM
rageglide's Avatar
Ah. Sorry i missed the response 'till just now. I was wondering why you weren't just yankin on the chrome disconnect.
Fuel quick disconnect help 10th Mountain Troubleshooting for Road Glides 13 08-24-2018 08:15 PM
Fuel leaking from quick disconnect fitting HELP!! JJSW1283 Engine Related 10 06-06-2014 02:58 PM
Lower Fairing Quick Disconnect Kit Yesca Equipment-RG 13 07-23-2012 06:15 AM
Tourpack Speaker Quick Disconnect Options Illiniroads Audio 5 03-06-2012 09:36 PM
RGU Hard bag locking quick disconnect problem ichiban Road Glide Specific Discussions 14 10-10-2010 08:45 PM
