Lower rocker box cover on M8 question - Road Glide Forums
 5Likes
post #1 of 12 (permalink) Old 07-12-2017, 09:23 AM Thread Starter
WFOFLTRXS's Avatar
I'm putting the black cover kit on my M8 when ever i find a few free hours on a weekend so i just wanted to get a game plan incase i need any special tools or need to know anything
Question 1: It looks like the tank will have to come off to replace the upper box cover does it?????
Question 2 the lower box covers do i need to remove the rockers or anything else to replace the lowers???
Either way ill be pulling them off to switch to the black ones, I just like to know what im getting into before i start taking it apart.
2017 FLTRXS velocity red, stage 1
WFOFLTRXS is offline
post #2 of 12 (permalink) Old 07-13-2017, 06:54 AM
norm9278's Avatar
1)Yes. 2) Yes. Get the manual. You will need to pull the rockers and push rods. Fuel will run out when you remove the cross over line, so empty the tank first.
geo8866 likes this.
norm9278 is offline
post #3 of 12 (permalink) Old 07-13-2017, 08:56 AM
Thermodyne's Avatar
Yes you will need to pull the tank.
Then it's the covers and the rocker arms, followed by the lowers. 8 bolts in the lowers.
You may need to pull the oil separator, not sure if it's in the way or not.
When you put the rockers back on, make sure the tappets are on base (valves closed) as you draw the shaft bolts tight. And draw them down evenly by hand. You'll also need some thread chasers to clean the old thread locker out of the bolt holes. Locktite won't hold if you don't clean the holes and bolts.
Thermodyne is offline
post #4 of 12 (permalink) Old 07-13-2017, 09:48 AM
WTFranz's Avatar
There was a real good YouTube out there that shows step by step and items to watch for. Not the M8 but sure its close.
https://www.youtube.com/watch?v=_AoAgXXfQxE
This one will give you a good idea of whats in store.
https://www.youtube.com/watch?v=8dQ1-A6Ig1w
geo8866 likes this.
Mazikeen - 2016 Road Glide Special from Arizona
WTFranz is offline
post #5 of 12 (permalink) Old 07-13-2017, 01:29 PM
RGKen's Avatar
You need to take great care and follow the manual during every step of this process if you must do this yourself. I have already heard of seasoned mechanics breaking the heads as the new design is much different than what is shown in the video's above on the TC engine. The M8 has the rocker arm shaft that goes through a molded section of the head and has a bolt that goes through it to hold it in place. This is different than the old rocker support plate that the twin cams have. If you do not follow the bolt torque sequence to the letter as well as the torque spec itself you have more than a great chance of breaking it. The only real similarity in the procedure to the twin cam is relieving the valve train pressure. If you have never worked on one of these before you may want to consider paying to have it done. That way if anything breaks, they are responsible.
Jacksprat56 likes this.
2018 FLTRXS
RGKen is offline
post #6 of 12 (permalink) Old 07-13-2017, 02:43 PM
norm9278's Avatar
I don't know what your experience level is as a mechanic, so be warned that this is not like changing the valve covers on a small block Chevy. You are not just removing a cover. It is a functional and structural part of the engine, and a screw up can cost you big time, and not covered by warranty.
RGKen likes this.
norm9278 is offline
post #7 of 12 (permalink) Old 01-28-2018, 06:37 AM
cjhd06's Avatar
My dealer told me the m8 is designed differently and the rocker arms do not need to be removed the lower covers fit around them but the rear bolts are a b**** go get to don't know for a fact but that's what I was told. Id like to know im about to do the same project.
cjhd06 is offline
post #8 of 12 (permalink) Old 01-28-2018, 09:20 AM
skratch's Avatar
dealer doesn't know what he's talking about..... (imagine that )
File Type: png Screen Shot 2018-01-28 at 9.17.09 AM.png (339.0 KB, 56 views)
Little Wing likes this.
skratch is offline
post #9 of 12 (permalink) Old 01-29-2018, 03:45 AM
cjhd06's Avatar
Yeah that's a shocker lol do you have install instructions for upper rockers and how to remove the lines over the top of them?
cjhd06 is offline
post #10 of 12 (permalink) Old 01-29-2018, 05:24 AM
skratch's Avatar
no problem....
File Type: png Screen Shot 2018-01-29 at 5.20.10 AM.png (281.9 KB, 40 views)
File Type: png Screen Shot 2018-01-29 at 5.20.45 AM.png (91.7 KB, 35 views)
File Type: png Screen Shot 2018-01-29 at 5.14.48 AM.png (287.7 KB, 38 views)
File Type: png Screen Shot 2018-01-29 at 5.15.03 AM.png (46.7 KB, 32 views)
File Type: png Screen Shot 2018-01-29 at 5.15.24 AM.png (234.2 KB, 32 views)
skratch is offline
Spider cracks in lower rocker box plate? modot66 Engine Related 20 01-05-2018 08:20 AM
Rocker box cover seep Punishher7 Engine Related 14 05-29-2017 08:14 PM
Rocker box cover leak / 2015 RG HardLuck5150 *General Road Glide Discussions/Pictures 10 10-13-2016 10:05 AM
Removing Rocker Box Cover Q-Hog Engine Related 2 03-12-2013 04:22 PM
Gloss Black HD Detachable Sissy Bar/Rocker Box Covers/Cam Cover Bigdaddymike Classifieds Archive (3 months old+) 7 01-26-2012 04:27 PM
