Outer Primary Change - Road Glide Forums
post #1 of 8 (permalink) Old 04-08-2013, 09:05 PM Thread Starter
I recently ordered a gloss black outer primary, can I just unbolt the chrome one and replace or do I need to drain fluid? thanks any assistance would be greatly appreciated.
METIME is offline
post #2 of 8 (permalink) Old 04-08-2013, 09:10 PM
If you just unbolt it it will just pour out all over. I recomend you drain it and buy a new gasket to replace the old one.
RGC Vivid Black,Yaffe extended BagsRC Components "Calypso" Chrome wheels,with matching rotors,HHI Stripper Bars,CFR Slip-Ons CAT Removed
Louster47 is offline
post #3 of 8 (permalink) Old 04-08-2013, 09:24 PM
mjsdouble's Avatar
I'm no expert by any means. I've literally only changed Primary 4 times. During the refill the bike is level on the bike jack. Then the cover is put on. I'm thinking there's no reason you'd need to drain it. The gasket can also be reused depending on its condition. I'd have a new one on hand just in case you need it.
mjsdouble is offline
post #4 of 8 (permalink) Old 04-08-2013, 09:36 PM
TRUBlue's Avatar
If you are referring to just the derby cover, swap 'em without draining, if you're talking about the whole primary, yes, drain first, I don't know of another way. Oil's cheap, gaskets & o-rings too.
'12 FLTRU Big Blue Pearl
TRUBlue is offline
post #5 of 8 (permalink) Old 04-08-2013, 09:48 PM
mjsdouble's Avatar
Never came to mind OP would be referring to Primary Cover as opposed to the Derby. I read it wrong and thought he was talking about the Derby. TRUBlue is correct on all accounts. Including the oil, gaskets and o-rings.
post #6 of 8 (permalink) Old 04-09-2013, 10:59 AM
Phantom6722's Avatar
+1 for what Trublue said only thing to add is, maybe a better aftermarket primary gasket and O-ring kit.
Cheers Skip
Phantom6722 is offline
post #7 of 8 (permalink) Old 04-16-2013, 08:46 PM
Be careful removing the Torx bolts on your derby cover. I just did my service and had a stripped one I had to drill out. Make sure you have the proper tools to remove the bolts.
Minivend is offline
post #8 of 8 (permalink) Old 04-16-2013, 10:36 PM
rageglide's Avatar
Torx suck! I'm sure they work great for a manufacturing environment. But real world, they are junk. Soft crappy torx like Harley uses suck even worse than good torx. I've twisted the torx bits more times than allen. When a Torx comes out, an Allen goes back in it's place.
rageglide is offline
2009 Chrome Outer Primary and Derby Cover METIME Parts for Sale 3 06-11-2013 11:49 AM
Inner and Outer Primary METIME Parts for Sale 1 05-31-2013 10:20 AM
Chrome Outer Primary Cover Harley 60506-99 Shrug Parts for Sale 0 05-24-2013 08:25 PM
2008 Outer Primary Cover Corrupted Parts for Sale 1 05-07-2013 07:41 AM
Dash w/ gas door, rear mc chrome cover, & outer primary Swagzilla Parts for Sale 1 01-11-2013 09:55 AM
