Battery troubleshooting - Road Glide Forums
post #1 of 24 (permalink) Old 08-14-2017, 04:08 PM Thread Starter
Thegreencantina's Avatar
2012 FLTRX. Never had any issues starting. No slow starts or dragging starter. Sometimes parked for weeks with no issues. Suddenly today battery was dead to the point of barely turning the starter. Rode it two days ago. Nothing left on. I have never had a battery take a shit that suddenly. Bike stored indoors and temperature is around 80 inside.
Anyone have a battery go this fast? Any suggestions on troubleshooting other causes (short, charging, etc) before forking out for a new battery?
Haven't done any work or washed it recently.
Thanks.
Sent from my SM-G935V using Tapatalk
What don't kill you, make you more strong.
Thegreencantina is offline
post #2 of 24 (permalink) Old 08-14-2017, 05:06 PM
Use a voltmeter to see what the battery has for volts or take it out and and bring it somewhere to have it tested. It is possible that a battery can go bad quickly.
post #3 of 24 (permalink) Old 08-14-2017, 05:10 PM
Check your connections.
post #4 of 24 (permalink) Old 08-14-2017, 06:27 PM Thread Starter
The posts were spotless and the cables were tight.
post #5 of 24 (permalink) Old 08-14-2017, 07:10 PM
Check the other end of the ground , then do what rlaf75 said.
RGKen likes this.
post #6 of 24 (permalink) Old 08-14-2017, 07:14 PM
SCovelli's Avatar
You need to have the battery load tested. You may also want to have a battery tender plugged into the battery if it's left in the garage for more than a few days.
2016 FLTRUSE
SCovelli is offline
post #7 of 24 (permalink) Old 08-14-2017, 07:23 PM
RGKen's Avatar
A loose or corroded ground can cause this issue so everything stated above is where I would start. Also, if this is the original battery you have got your money's worth out of it so a new battery could be in order.
2018 FLTRXS
RGKen is offline
post #8 of 24 (permalink) Old 08-15-2017, 07:22 AM
SteveH's Avatar
FWIW I keep a jump box around just for that type of situation. It sux
2017 Road Glide Ultra, Black Quartz, CD leds & flashers, Electra Glo Keystone Auxiliary LED Run/Brake/Turn Lamps, Rinehart 4.5" slip-ons, T-Bag lid covers, LRS 15" Thresher, Powder coated wheels
SteveH is offline
post #9 of 24 (permalink) Old 08-15-2017, 07:56 AM
BlueBagger12's Avatar
Batteries fail as much in warm/hot weather as in cold. I'd bet battery is done but imperative to check all grounds. A little dialectric grease goes a long way, just look at the back of your fuse block some time.
Don't fail us now, oh blessed mother of acceleration...
BlueBagger12 is offline
post #10 of 24 (permalink) Old 08-15-2017, 09:09 AM
norm9278's Avatar
All good advise here. Remember that every cable has two ends. Don't just look at them, take them apart and clean them. Dialectric grease is good preventative maintenance. If you are still running the factory battery after 5 years, it doesn't owe you anything.
You can pick up a battery maintainer for $15 at Wally World.
norm9278 is offline
Troubleshooting a Baker OD6 Stick_FSMC Troubleshooting for Road Glides 1 06-20-2013 03:15 PM
Troubleshooting dead HK radio? RGCBandit Audio 15 10-22-2012 11:39 PM
Need help troubleshooting J&M Rokker installation Stick_FSMC Audio 18 07-01-2012 11:34 AM
Need help troubleshooting J&M Rokker installation Stick_FSMC J&M 2 06-04-2012 11:12 AM
Beer troubleshooting Eric92 General Off-Topic Discussions 11 12-26-2011 08:15 AM
