2013 Road Glide Stator replacement - Road Glide Forums
 4Likes
post #1 of 14 (permalink) Old 08-24-2017, 09:48 AM Thread Starter
tclaibourne's Avatar
OK, I have the manual, looked online at various videos, and now must ask the question. Do I have to remove the inner primary to replace the stator on the 2013 Road Glide Custom? Older models you didn't have to. It seems there is a lip that doesn't allow clearance to remove the rotor/compensator assy. Does Harley do this just to discourage do it yourself'ers?
tclaibourne is offline
post #2 of 14 (permalink) Old 08-24-2017, 10:10 AM
HellInABucket's Avatar
A lot of folks grind that lip off
tclaibourne likes this.
2018 FLTRU
Roll away the dew...
HellInABucket is online now
post #3 of 14 (permalink) Old 08-24-2017, 10:14 AM Thread Starter
Really? Looking at older models, the lip isn't there and the wall thickness is thinner on them. I am a little apprehensive on grinding away on the primary. Thanks for the info.
post #4 of 14 (permalink) Old 08-24-2017, 11:55 AM
Dragon Dude's Avatar
It's just like 5 bolts to remove the inner. Just me, but i would not grind on the inner primary, it's to easy to remove it.
Dragon Dude is offline
post #5 of 14 (permalink) Old 08-24-2017, 12:05 PM
snarley53's Avatar
just 5 bolts, after you remove the entire clutch assy,?
2011 roadglide ultra.2000 93" s&s rigid panhead,
40 ford rat rod pickup
snarley53 is offline
post #6 of 14 (permalink) Old 08-24-2017, 12:06 PM
Do it! I just did this on my 12rgu. I used a dremel and barely removed any material, No issues. I was also able to change stator without removing clutch assembly.
bigdoug1130 is offline
post #7 of 14 (permalink) Old 08-24-2017, 12:18 PM Thread Starter
Do I have to totally dismantle the clutch assy or will it remove as one unit?
post #8 of 14 (permalink) Old 08-24-2017, 01:16 PM
Undo and loosen the clutch adjustment nut and allen screw, pull the C clip and remove the adjuster part and there is a nut behind it, left hand thread to remove. It will slide out, if the chain is off.
post #9 of 14 (permalink) Old 08-24-2017, 01:38 PM Thread Starter
Thanks, Got to the bolt. Gotta run and get a 1 3/16th socket. After all the tools and part I bought, it might have been cheaper to have it done. Thanks for the advice. All because of a bad stator. Hope I never have to replace another one.
post #10 of 14 (permalink) Old 08-24-2017, 02:28 PM
Stoic Joker's Avatar
The 13 shows as having the same inner primary as my 10, and I pulled mine without pulling the primary or cutting anything. It took a bit of wiggling but it came out just fine ... albeit sideways IIRC.
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is offline
Tags
road glide , stator
2013 Road Glide Fork Oil replacement josephkram54 Do-IT-Yourself 7 06-09-2018 11:08 PM
Stator Problems on New Bike Klaffey Troubleshooting for Road Glides 3 04-26-2012 03:30 PM
stator/regulator dddboat Troubleshooting for Road Glides 8 04-03-2012 06:30 PM
How long does it take to change a stator? ironmark *General Road Glide Discussions/Pictures 10 01-31-2012 09:27 PM
Oil Leak from Stator Wiring? jcanrun *General Road Glide Discussions/Pictures 8 01-06-2011 02:15 PM
