2008 and up Fuel Filter Replacement - Road Glide Forums
post #1 of 3 (permalink) Old 04-25-2013, 07:54 AM Thread Starter
OldNerdGuy's Avatar
What does your Fuel Filter look like?
Does it look like the one on the left? Or the one on the right?
Don't know? Don't feel bad, it is not something you can just inspect.
Here is a video I used as a guide to replacing my fuel filter.
http://www.youtube.com/watch?v=SYOsc7NBhBo
PULL THE MAIN FUSE BEFORE YOU START THIS!!!
A few issues I ran across.
First, removing the cam lock ring on the tank. The guy in the video made a really cool tool to remove the ring. I used a simpler method which involved a Blunt Object and a Dead Blow Hammer. Here is a picture I swiped from another forum that shows exactly how I did it. I just did not label my "blunt object". If it gets stubborn coming off, move around and hit different tabs. Going on, reverse it. Hit a few tabs to get them all seated, then you can just hit the most convenient tab to drive it all the way on. I used a Dead Blow Hammer as that tends to reduce the hammer rebound (keeps you from dinging the tank).
Caution: Put a towel between the blunt object and the tank to avoid scratches.
Second issue. I did NOT remove the hoses or wires, but did the replacement with the top plate hanging out of the tank. It worked, but I would recommend removing it. If you do not, you are working in Gasoline, and over a big hole in the tank. I would NOT recommend putting a rag in the tank to catch anything that falls, unless you are trying to make the World's Fastest Molotov Cocktail. Just be VERY CAREFUL not to drop anything in the tank. The only thing I removed was the retaining U-Clip on the filter. Getting the whole Top Plate assembly in and out of the tank was an adventure. Just be patient, you can get it far enough out to replace the filter. Just be advised, you are working over and in Gasoline (see Molotov Cocktail warning above).
Third issue. Putting the filter housing back together was not easy, I had to force the two pieces together. The new filter holes were tight, and they have to be pushed together. There is only one way they align, there is a SMALL tab that lines them up, don't break it. Use firm pressure, do not push too hard lest ye break something (think Top Plate replacement $$$)
The problem that I was having was rough idle, and poor performance off idle. Pulling away from a stoplight was becoming an adventure, even on level pavement. The filter above has, at least, 42,000 miles on it. I never replaced it until now. Once I got the new filter in, the bike idles much better, and off-idle performance is vastly improved.
OldNerdGuy is offline
post #2 of 3 (permalink) Old 04-25-2013, 08:07 AM
Mischief's Avatar
Damn!! That is something I am not looking forward to doing. What a pain in the a$$ for something that should be (fairly) routine maintenance!!!!
2012 FLTRU
Mischief is offline
post #3 of 3 (permalink) Old 04-25-2013, 08:29 AM Thread Starter
OldNerdGuy's Avatar
Yeah, but I think it is like removing the front fairing. Once you have done it, it gets easier. And it is well worth the effort. It took me about an hour to get it done, but that was because I did not remove the top plate hoses and wires.
any videos showing fuel filter replacement? CPY84 Do-IT-Yourself 4 11-05-2016 05:58 PM
K&N Filter vs.HD Oil Filter RRHartzler Fluids and Lubricants 49 10-22-2016 07:00 PM
any good instructions to remove 2011 fuel tank to replace fuel filter? CPY84 Do-IT-Yourself 9 10-10-2016 11:31 PM
Need Help! Selecting Oil, Oil Filter & Air Filter Big Red 103 Do-IT-Yourself 5 06-06-2011 11:38 AM
k & n filter to replace SE stage 1 filter raven006 ECM/Fuel Management systems 5 11-22-2010 04:24 PM
