Removing R/Tail Light Bar & License Plate Bracket - Road Glide Forums
 2Likes
post #1 of 17 (permalink) Old 10-14-2017, 03:33 PM Thread Starter
I have a 2018 RGS and going to install the HD curved license plate bracket to the original tail light bar. There is not enough room between the bracket and the fender just to remove the bracket from the tail light bar. It looks like one can do that with the rear tire still mounted?? Has anyone done this without removing the rear tire or jacking up the bike some for more room between the tire and mounting bolts to the tail light bar? I looked it up in my 2015 shop manual(I wanted a 18 shop manual, but now they are over $100) and it does not really indicate the need to remove or jack the bike up a bit.
Thanks
FLTRXS18 is offline
post #2 of 17 (permalink) Old 10-14-2017, 03:44 PM
bucketlisthd's Avatar
I did my 15 RGS with the tire on. Don't recall if I jacked it or not. I think that it's doable lying down with the right tool combination. No idea what that was at this point.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #3 of 17 (permalink) Old 10-14-2017, 04:40 PM
AJsix's Avatar
Yep - did it on my 17 RGS to get rid of the reflector. Lay on your back and reach up between the tire and fender - I believe I use a boxed end wrench - just have to feel your way through it. Not much throw on the wrench turns so it will take a minute to get the bolts off. Easily doable.
madmat likes this.
AJsix is offline
post #4 of 17 (permalink) Old 10-14-2017, 05:21 PM Thread Starter
All, thanks for the replies.
FLTRXS18 is offline
post #5 of 17 (permalink) Old 10-14-2017, 05:24 PM
Same thing I did. It sucked but got it.
Smoke338 likes this.
Dave I. is offline
post #6 of 17 (permalink) Old 10-14-2017, 07:15 PM
Smoke338's Avatar
I did the same.
I stopped counting after 12 million quarter turns of the box end wrench............
Smoke338 is offline
post #7 of 17 (permalink) Old 10-14-2017, 07:29 PM
You could try a 1/4" drive ratchet, or maybe a thumb wheel ratchet.
'87 FXR 100"
'79 Goldwing cafe
post #8 of 17 (permalink) Old 10-15-2017, 11:49 AM Thread Starter
All, thanks for the input
FLTRXS18 is offline
post #9 of 17 (permalink) Old 10-15-2017, 03:59 PM
If you have a ratchet wrench with a flex head it will be much easier.
2015 Road Glide Special
TENGEL78 is offline
post #10 of 17 (permalink) Old 10-15-2017, 04:06 PM Thread Starter
Thanks for the info, depending on what size I may have that.
FLTRXS18 is offline
2015 CVO rear light bar removal (license plate relocation) WSNuke Aftermarket Accessories 0 04-02-2018 03:37 PM
09 and up license plate bracket & brake light lens yzergod Parts for Sale 1 05-06-2014 11:33 AM
Wtb license plate relocate kit/bracket 11FLTRX103 Wanted! (Buy or Trade) 1 06-13-2012 10:34 PM
Yaffe License Plate Bracket METIME Aftermarket Accessories 1 09-14-2011 09:24 PM
License Plate Relocator Bracket sportyguy69 Aftermarket Accessories 9 06-20-2011 08:16 PM
