2016 RGS bike-to-bike (cb) install - Road Glide Forums
  • 1 Post By canderso1970
post #1 of 7 (permalink) Old 10-26-2017, 04:39 PM Thread Starter
Riderdave's Avatar
Thumbs up 2016 RGS bike-to-bike (cb) install
I wanted to thanks those that helped me with my CB install. The forum and the internet provided me with a great deal
of information that I wanted to give back. So I decided to post it in one place.
I am attaching JPEGS of the info until I can figure out a better way. If someone can tell me how to post this better let me know
I hope this helps someone out there.
I did not know the JPEG had shrunk my template. Please message me so I can get you a full size template
Riderdave is offline
post #2 of 7 (permalink) Old 10-26-2017, 06:18 PM
canderso1970's Avatar
Nice job on the write up Riderdave. I recently installed the factory CB, WHIM and a Firestick antenna. I didnít have a lot of faith in the factory antenna. I have no evidence to support that concern however.
I have some expensive antenna tuning equipment and went with a non-ground plane antenna and was able to customize the wire length and use a shorted-stub configuration to dial into a 1:1.4 SWR.
I am interested to hear your results on the factory antenna.
Looks like the bracket turned out nice.
Smoke338 likes this.
canderso1970 is offline
post #3 of 7 (permalink) Old 10-26-2017, 07:41 PM Thread Starter
Riderdave's Avatar
Thanks for your response. As you can tell, I am not a computer wiz. So far I am not impressed with the antennas I have (shorties). Next attempt will stock height 33" . Learning curve, may visit a CB shop soon, to see if they can help me.
post #4 of 7 (permalink) Old 10-29-2017, 10:55 PM Thread Starter
Riderdave's Avatar
What would the correct SWR for the Harley CB ?
post #5 of 7 (permalink) Old 10-30-2017, 10:31 AM
Riderdave-
You want to have an SWR below 2:1. The ideal is a 1:1 ratio. The closer to that the better. I forget what the top range of unacceptable would be. Once you get in the 4:1 or 5:1 range you may risk damaging your radio. I think 3-3.5:1 is still workable without damage, but your range will suffer greatly.
-c
2016 Road Glide Special - Velocity Red
1976 Ironhead Hardtail Bobber - Citron Mist Metallic, Hand built by me
post #6 of 7 (permalink) Old 10-30-2017, 01:28 PM
If I did this right, attached below are two photos of my antenna setup. The first should be a picture of the antenna bracket that I made out of aluminum and the second photo should be with the factory HD AM/FM antenna mast on the left and the 4' fiberglass Firestick antenna on the right.
Perhaps not aesthetically pleasing to some, but it is highly effective.
-c
post #7 of 7 (permalink) Old 11-01-2017, 06:53 PM Thread Starter
Riderdave's Avatar
Thanks, just what I needed. I always get answers here.
2016 RGS CB Antenna Mount Riderdave Audio 5 10-15-2017 09:21 PM
CB for 2017 RGS Ozglide11 Tech Area 2 08-09-2017 07:00 AM
CB on RGS Azblu *General Road Glide Discussions/Pictures 3 04-28-2017 04:14 PM
2017 RGS CB compatibility Azblu Audio 0 02-23-2017 09:47 PM
2016 RGS or 2017 RGS? PEZRACER *General Road Glide Discussions/Pictures 11 09-01-2016 02:14 PM
